openHAB 5.1 Release discussion
Hi, I’m currently using OH5.1.2 Docker image and observe an issue with time series. I think this is since time series got introduced.
For a given time series like from a binding channel or even when I create a time series in a rule, there is an Item assigned which gets persisted both in rrj4db as well as in inmemory service (as member of a group). When the time series runs out, so no new data available the Item gets stuck with the last value even when the time series gets updated later with new data. I have to re-safe the Item in the GUI to get it refreshed and following the current state of the time series. Am I doing something wrong or is the a bug?
Just installed 5.1.3 on my ubuntu system.
Unfortunately file based things are not loaded anymore at startup :frowning: e.g. items and pages are loaded.
No warning/error message in log files …
Has anything changed related to this, i need to adapt?
“not loaded” seems bit ambiguous ..
Thing list is reported to be empty, on web page as well on console.
Addons are loaded and started.
But thing inbox reports just the things i usually haven’t configured.
Question might be, why are not all the other things reported?
Meanwhile i downgraded to 5.1.2, and everythings works as before and expected.
The core changes seem unrelated to this to me. What is your environment? Also check permissions.
Openhab runs within a kvm based VM, on top of Ubuntu 24.04.4 LTS
All thing files are owned by user “openhab” with exclusive rw permissions, similar to item files (which seems to get loaded).
I wonder a bit about the discrepancy about thing inbox and on a first glance not loaded things ..
The issue seems to be very weird, as there aren’t many code changes and they seem correct. Anything in the logs? Permissions still correct after the upgrade? Have you tried restarting openHAB or clearing cache after the upgrade (cache should already be cleared, and this shouldn’t depend on cache clear)?
Nothing at all in the logs with starting severity of WARN.
I stopped, paused and started openhab severall times, with same result.
I haven’t cleared the cache at anytime.
But rolling back to 5.1.2 did the job with the first try.
Are there any debug options or anything else i could try?
! Everything’s working now !
I just setup the whole VM from scratch via ansible. Everything works as expected, thing files are loaded, hairlines are there and action photos works as well.
Finally i’m not sure on whether this was related to any cache issue or something else :frowning: I run pretty much the same ansible scripts as before, when up-/down- grading. Personally i’m more in favour of getting to know what went wrong :frowning:
Sorry for any confusion, and thanks a lot for your support!
.. what just came to my mind, i haven’t restarted the VM before, maybe that would have solved my issue as well.
The following error was displayed during the update to version 5.1.3:
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://davesteele.github.io/comitup/repo comitup InRelease: The following signatures were invalid: EXPKEYSIG 0959C4A3DCF89FBF David Steele <steele@debian.org>
W: Failed to fetch http://davesteele.github.io/comitup/repo/dists/comitup/InRelease  The following signatures were invalid: EXPKEYSIG 0959C4A3DCF89FBF David Steele <steele@debian.org>
W: Some index files failed to download. They have been ignored, or old ones used instead.
All, please don’t continue posting any sort of xxx-doesn’t-work-after-upgrading issues like those last ones but make sure they are on topic.
There’s special conditions to apply to this thread, see openHAB 5.1 Release discussion - #218
Please make sure to meet these requirements to help maintain this thread being a useful resource to all openHAB users. Thank you.
Looks like
How do you figure that?
The symptoms :slight_smile:
These are the symptoms in the post you replied to:
Maybe I forgot to mention milestone and 5.3 ? Or is it a feature :person_running: :dashing_away:
What do you mean by that?
The fact that you think you can “bully” people into making a fix is unfortunate, especially when we have nothing to go on. You consistently don’t respond to the feedback that “doesn’t fit your vision”, and then you somehow think that if you just make enough noise, somebody will “be forced” to fix it? You seem to miss the point that at this point, there is nothing anybody can do, because we have no indication of what goes wrong. The “bullying” only makes people less interested in helping.
I have a strange UI display problem in 5.1.3 with many oh-stepper-item widgets showing a 0 value.
When you change them, the true value appears and is correctly used as the starting point.
Reload also makes all values appear. But when I navigate elsewhere and back to the page it’s all 0 again. FWIW this is on a tabbed page.
I have some stepper widgets on the same page that work think it happens only for those widgets with enableInput: true.
I had a strange issue with a number of my rules, after upgrading to OH 5.1.3. I upgraded on 25 Feb, and everything ran fine for a few days, but on Feb 27th, I started getting a errors for some JS Scripts (Main UI based) - 3 different rules.
  • No changes were made to the rules
  • They did work prior to the 5.1.3 upgrade (have scanned older logs, and no related errors)
  • They also did work for 2 days following the 5.1.3 upgrade/restart of OpenHAB
  • Also checked APT logs - No updates made to system (e.g. Java version), since 5.1.3 upgrade
A restart of OpenHAB has resolved the issue, but as it appears to be transient, am posting here in case anyone else sees a similar issue, and a pattern is emerging.
I only could find one similar error mentioned back in 2022 ECMAScript 2021+ rule-based scripts fail when using cache.get(): The Context is already closed , where the user resolved by re-saving rules (And perhaps my restart did the same effect).
First, the environment:
runtimeInfo:
  version: 5.1.3
  buildString: Release Build
locale: en-NZ
systemInfo:
  configFolder: /etc/openhab
  userdataFolder: /var/lib/openhab
  logFolder: /var/log/openhab
  javaVersion: 21.0.10
  javaVendor: Azul Systems, Inc.
  javaVendorVersion: Zulu21.48+17-CA
  osName: Linux
  osVersion: 6.17.0-14-generic
  osArchitecture: amd64
  availableProcessors: 16
  freeMemory: 1753354080
  totalMemory: 2147483648
  uptime: 399
  startLevel: 100
addons:
  - automation-jsscripting
  - binding-amazonechocontrol
  - binding-astro
  - binding-cbus
  - binding-chromecast
  - binding-daikin
  - binding-denonmarantz
  - binding-exec
  - binding-fineoffsetweatherstation
  - binding-gpstracker
  - binding-heos
  - binding-http
  - binding-icalendar
  - binding-ipcamera
  - binding-ipobserver
  - binding-logreader
  - binding-modbus
  - binding-mqtt
  - binding-network
  - binding-ntp
  - binding-onkyo
  - binding-opensprinkler
  - binding-openweathermap
  - binding-samsungtv
  - binding-serial
  - binding-snmp
  - binding-solarforecast
  - binding-spotify
  - binding-systeminfo
  - binding-tuya
  - binding-unifi
  - misc-openhabcloud
  - persistence-influxdb
  - transformation-bin2json
  - transformation-exec
  - transformation-jsonpath
  - transformation-map
  - transformation-regex
  - transformation-rollershutterposition
  - transformation-scale
  - transformation-xpath
  - transformation-xslt
  - ui-basic
  - ui-habpanel
clientInfo:
  device:
    ios: false
    android: false
    androidChrome: false
    desktop: true
    iphone: false
    ipod: false
    ipad: false
    edge: false
    ie: false
    firefox: false
    macos: false
    windows: false
    cordova: false
    electron: false
    capacitor: false
    nwjs: false
    webView: false
    webview: false
    standalone: false
    pixelRatio: 1.25
    prefersColorScheme: dark
  isSecureContext: true
  locationbarVisible: true
  menubarVisible: true
  navigator:
    cookieEnabled: true
    deviceMemory: 8
    hardwareConcurrency: 16
    language: en-NZ
    languages:
      - en-NZ
      - en-GB
      - en-US
      - en
    onLine: true
    platform: Linux x86_64
  screen:
    width: 3072
    height: 1728
    colorDepth: 24
  support:
    touch: false
    pointerEvents: true
    passiveListener: true
    intersectionObserver: true
  themeOptions:
    dark: dark
    autoDarkMode: true
    bars: light
    homeNavBar: default
    homeBackground: default
    disableExpandableCardAnimation: false
    blocklyRenderer: null
    disablePageTransitionAnimation: false
    hideChatInput: false
    webAudio: false
    visibleBreakpointDisabled: true
  userAgent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like
    Gecko) Chrome/145.0.0.0 Safari/537.36
timestamp: 2026-03-03T18:34:58.177Z
And it looks like I am running OpenHAB Rules Tools 2.0.3 (Using TimerMgr)
Secondly the errors:
2026-02-27 10:01:56.971 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 15:52:25.314 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 15:52:25.316 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 15:52:25.317 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 20:29:42.000 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 20:29:42.003 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 20:29:42.006 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 21:52:39.050 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 21:53:34.235 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 21:53:34.237 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 21:53:34.238 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 21:54:35.275 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 21:54:36.540 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 21:54:45.741 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-27 21:54:47.003 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-28 17:30:46.589 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-02-28 17:31:37.965 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-01 00:52:20.094 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-01 01:03:31.273 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-01 15:05:00.100 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-01 15:09:34.720 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-01 17:45:19.992 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-01 17:46:58.214 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-02 07:13:25.482 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-02 07:13:25.484 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-02 07:13:25.487 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-02 17:36:59.972 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-02 17:36:59.974 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-02 17:36:59.975 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-02 19:21:17.086 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 07:00:19.609 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 07:00:19.611 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 07:00:19.613 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 17:39:05.086 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 17:39:05.087 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 17:39:05.088 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 19:15:02.287 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 19:28:56.456 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 19:28:58.429 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 19:49:24.015 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'depart_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 22:28:48.143 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 22:28:48.145 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 22:28:48.146 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'arrive_house_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 22:54:58.218 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 23:20:46.460 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-03 23:20:46.461 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-04 07:27:28.036 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
2026-03-04 07:27:30.796 [ERROR] [.handler.AbstractScriptModuleHandler] - Script execution of rule with UID 'gate_force_control' failed: java.lang.IllegalStateException: The Context is already closed.
And lastly, the scripts called out in the above errors:
gate_force_control:
configuration: {}
triggers:
  - id: "1"
    configuration:
      itemName: Gate_Open_force
  - id: "3"
    configuration:
      itemName: Gate_ButtonLights_force
  - id: "4"
    configuration:
      itemName: Gate_Lights_force
conditions: []
actions:
  - inputs: {}
    configuration:
      type: application/javascript
      script: >-
        if(event.itemName != undefined)
        //Stops script from running if triggered via OpenHAB console - Event
        would be undefined, and fail
          var {TimerMgr} = require('openhab_rules_tools');
          var timers = cache.shared.get('gate_tm', () => TimerMgr());
          triggeringItem = items[event.itemName].name
          if(triggeringItem.indexOf("_force") === (triggeringItem.length()-6))
              otherItem = triggeringItem.substring(0,triggeringItem.length()-6)
            else
              otherItem = triggeringItem + "_force"
          if (items[otherItem].state != items[triggeringItem].state) {
            console.log("Gate Force Rule Running - Triggered by",triggeringItem,"- Changing item state for",otherItem,"to",items[triggeringItem].state);
            items[otherItem].sendCommand(items[triggeringItem].state);
            timers.check(otherItem+"_off_tm",0,null,false,null,otherItem+"_off_tm");
          if((triggeringItem === "Gate_Open_force") && (items["Daylight"].state === "OFF") && (items["Gate_Open_force"].state === "ON"))
           items["Gate_Lights_force"].sendCommandIfDifferent("ON");
           items["Gate_ButtonLights_force"].sendCommandIfDifferent("ON");
           console.log("Gate Force Rule - Turning on force lights");
          if((triggeringItem === "Gate_Open_force") && (items["Gate_Open_force"].state === "OFF"))
           items["Gate_Lights_force"].sendCommandIfDifferent("OFF");
           items["Gate_ButtonLights_force"].sendCommandIfDifferent("OFF");
           console.log("Gate Force Rule - Turning off force lights");
    type: script.ScriptAction
arrive_house_control:
configuration: {}
triggers:
  - id: "1"
    configuration:
      itemName: ZelioAlarmArmed
      previousState: ON
      state: OFF
conditions: []
actions:
  - inputs: {}
    label: PIR Enable Scene
    description: Run Arrive House - PIR Enable Scene
    configuration:
      considerConditions: false
      ruleUIDs:
        - arrive_house_PIR_enable
    type: core.RunRuleAction
  - inputs: {}
    label: Un-Dim cBUS Key Switches Scene
    description: Run Arrive House = UnDim CBUS Key Switches Scene
    configuration:
      ruleUIDs:
        - arriveHouse_unDimCBUSKeySwitches
  - inputs: {}
    label: Arrive House - Close Gate
    description: Set a timer for auto-closure of the gate
    configuration:
      script: |-
        // This rule is used to set a timer to auto close the gate, when Arriving at the house (Alarm is Unset)
        // Remember that the Gate Controller itself has a Open timer, so unless its configured open duration has already been exceeded, releasing
        // the gate item may not result in immediate closure of the gate
        // The gate 'force' item is also set to off
        itemName = "Gate_Open";
        force_itemName = "Gate_Open_force";
        duration_itemName = "ArriveHouse_GateCloseDuration";
        duration = Number(items[duration_itemName].state);
        var tmexpire = function(iname,forceiname) {
          return () => {
            items[iname].sendCommandIfDifferent("OFF");
            items[forceiname].sendCommandIfDifferent("OFF");
        schedtime = time.ZonedDateTime.now().plusSeconds(duration);
        timers.check(itemName+"_off_tm",schedtime.toString(),tmexpire(itemName,force_itemName),true,null,itemName+"_off_tm");
  - inputs: {}
    label: Arrive House - Gate Garden Lights
    description: Turn off Gate Garden Lights if not Daylight, when arriving at house
      (Alarm Un-Set)
    configuration:
      script: |-
        // This rule is used to set a timer to auto turn off the Gate Garden Lights, when Arriving at the house (Alarm is Unset)
        // The gate garden light 'force' item is also set to off
        // Just bear in mind the Gate Force Rule may also turn off the lights when the Gate force is released
        itemName = "Gate_Lights";
        force_itemName = "Gate_Lights_force";
        duration_itemName = "ArriveHouse_GateGardenLightDuration";
          return () => {
  - inputs: {}
    label: Arrive House - Gate Button Lights
    description: Turn off Gate Button Lights if not Daylight, when arriving at house
      (Alarm Un-Set)
    configuration:
      script: |-
        // This rule is used to set a timer to auto turn off the Gate Button Lights, when Arriving at the house (Alarm is Unset)
        // The gate button light 'force' item is also set to off
        itemName = "Gate_ButtonLights";
        force_itemName = "Gate_ButtonLights_force";
        duration_itemName = "ArriveHouse_GateButtonLightDuration";
          return () => {
depart_house_control:
configuration: {}
triggers:
  - id: "1"
    configuration:
      previousState: OFF
      state: ON
conditions: []
actions:
  - inputs: {}
    label: Dim cBUS Key Switches Scene
    description: Run Depart House - Dim cBUS Key Switches Scene
    configuration:
      ruleUIDs:
        - departHouse_DimCBUSKeySwitches
  - inputs: {}
    label: Turn off loads Scene
    description: Run Depart House - Turn off loads Scene
    configuration:
      ruleUIDs:
        - depart_house_loads
  - inputs: {}
    label: PIR Disable Scene
    description: Run Depart House - PIR Disable Scene
    configuration:
      ruleUIDs:
        - depart_house_PIR_disable
  - inputs: {}
    label: Depart House - Gate Button Lights
    description: Turn on Gate Button Lights if not Daylight, when departing house
      (Alarm Set)
    configuration:
      script: >-
        // This rule is used to turn on the Gate Button Lights and set a timer
        // This will only turn on the button lights if night time (Astro managed
        item)
        // This version runs upon Departing the house (Alarm Set)
        duration_itemName = "DepartHouse_GateButtonLightDuration";
          return () => {
        if(items["Daylight"].state === "OFF")
         items[itemName].sendCommandIfDifferent("ON");
  - inputs: {}
    label: Depart House - Gate Garden Lights
    description: Turn on Gate Garden Lights if not Daylight, when departing house
      (Alarm Set)
    configuration:
      script: >-
        // This rule is used to turn on the Gate Garden Lights and set a timer
        // This will only turn on the garden lights if night time (Astro managed
        item)
        duration_itemName = "DepartHouse_GateGardenLightDuration";
          return () => {
  - inputs: {}
    label: Depart House - Gate Open
    description: Open the gate when departing the house, and set a timer for auto-closure
    configuration:
      script: |-
        // This rule is used to turn open the Gate and set a timer to auto close the gate, when the house is 'Departed' (Alarm is Set)
        console.info("Opening Gate Rule running")
        duration_itemName = "DepartHouse_GateCloseDuration";
          return () => {
Again, for now, a restart resolved the issue, but just keen to see if anyone has experienced a similar issue recently (Or maybe I am doing something dumb in the above scripts, which I ‘got away’ with’ in previous versions, and less so now !!)
Cheers
