Deploying a 5.0.0-SNAPSHOT binding to 4.3 release instance can be done (as long as there are not breaking API changes) as follows:
You need a Java 21 compiler, no need for a Java 17 compiler.
- Run your 4.3 instance on Java 21. OH 4.3 perfectly runs on Java 21 as well. openHABian-config can be used to switch to Java 21 on RPI. Keep in mind that the future-proof setup is a 64-bit system, at some point in time a binding might require a 64-bit system. OH5 bindings compiled for Java 21 can be deployed just as usual.
or - Keep your 4.3 instance running on Java 17. Use Java 21 to compile your binding, but generate Java 17 code. We have a profile
j17in place in the addons repo to do this without modifying the pom file:mvn install -Pj17 -Dohc.version=4.3.0. This will only work for bindings which do not require specific Java 21 libraries or features. Same remark as above: Keep in mind that the future-proof setup is a 64-bit system, at some point in time a binding might require a 64-bit system. IDEs might need some tweaking, otherwise you might end up with some Java 21 classes in the target folder.
tl;dr:
Run openHAB 4.3 on a 64-bit system with Java 21 if you want to use 5.0.0-SNAPSHOT bindings.
