Good evening all,
I am running Openhab 2.5.0~S1496-1 on a Raspbery Pi 3+ and SSD as primary storage, and have had no issues for a while but all of a sudden my HAB Panel has started to state:
“Connection lost! Trying to reconnect…”
After some initial investigations it appears that the call to <my_openhab_ip>:8080/rest/items is failing. Trying to call this directly (just using a web browser) the full json is sometimes returned, but more often than not it returns just:
{"error":{"message":"GET url \u0027https://alexa.amazon.co.uk/api/behaviors/entities?skillId\u003damzn1.ask.1p.music\u0027 failed: Bad Request","http-code":500,"exception":{"class":"org.openhab.binding.amazonechocontrol.internal.HttpException","message":"GET url \u0027https://alexa.amazon.co.uk/api/behaviors/entities?skillId\u003damzn1.ask.1p.music\u0027 failed: Bad Request","localized-message":"GET url \u0027https://alexa.amazon.co.uk/api/behaviors/entities?skillId\u003damzn1.ask.1p.music\u0027 failed: Bad Request"}}}
The Amazon Echo Control Binding has been installed from PaperUI (binding-amazonechocontrol - 2.5.0.SNAPSHOT) and I am able to check the account via http://<my_openhab_ip>:8080/amazonechocontrol/account1 and it correctly shows that the account is logged in and also shows all my devices. I am also able to control all of these devices correctly from within OpenHAB.
Now the obvious question is ‘what have you changed recently’ and ‘can you undo those changes’ however I have to confess that I can’t remember what I’ve done!!
My question to you all is what are my next steps in investigating and (hopefully) solving this issue? Unfortunately I use the binding, so uninstalling it and forgetting about it is not an option.
Any pointers would be greatly received!!
