@digitaldan
I’m trying to hook up the openhab-alexa skill, but I’m not grocking some of the setup.
I’ve been able to deploy the Lambda (although not sure how to configure a test event), but on the Alexa skill setup, I’m not sure what to use for Authorization URL, Scope, and the access info (Access Token URI and Client Secret).
Seaside, that’s a different approach by a different author. I was hoping to use this one because it uses an AWS Lambda instead of a dedicated internet-exposed service at home.
Smart home skills require an oauth connection, in the readme there is a link to Amazon Developers which describes how to use a amazon oath service instead of running your own. I highly suggest reading this as I would not be able to explain it more effectively.
I hope so, it’s been in review for weeks now, I will try pinging them again and see if they can hurry it up!
I guess I’ll be waiting for the official version… it sounds like I’d need to run an oauth service for Alexa, and then bake in my credentials for myopenhab. Meanwhile, I’m busy checking out my OH2 install.
Hopefully it will be availible, soon. The problem is, when you begun using this sh… with the hue emulation you just want more because it makes so much fun…
I am also facing the same issue .
As mentioned in the url below .
But , when i am using the same Authorization URl and Access token, i am unable to sync the devices which is attached to my web application
as my web url where iot devices are connected , is
@pratapvivek007: would you mind sharing which settings you used in the account linking form of the Alexa skill configuration (or where to get those URLs/credentials from)?
