I have a 4 relay board controlled from a nodeMCU controller running my sprinklers.
This is my arduino code
#include <ESP8266WiFi.h>
#include <MQTTClient.h>
/* WIFI Settings */
// Name of wifi network
const char* ssid = "Pretty_Fly_For_A_Wifi";
// Password to wifi network
const char* password = "9306023373";
/* MQTT Settings */
// Topic which listens for commands
char* subscribeTopic1 = "SprinklerSystem/Zone1";
char* subscribeTopic2 = "SprinklerSystem/Zone2";
char* subscribeTopic3 = "SprinklerSystem/Zone3";
char* subscribeTopic4 = "SprinklerSystem/Zone4";
char* publishTopic1 = "SprinklerSystem/Zone1/Stat";
char* publishTopic2 = "SprinklerSystem/Zone2/Stat";
char* publishTopic3 = "SprinklerSystem/Zone3/Stat";
char* publishTopic4 = "SprinklerSystem/Zone4/Stat";
char* publishTopic = "SprinklerSystem/State";
//MQTT Server IP Address
const char* server = "192.168.0.143";
//Unique device ID
const char* mqttDeviceID = "SprinklerSystem";
int channe1 = 16; //Zone1
int channe2 = 0; //Zone2
int channe3 = 2; //Zone3
int channe4 = 14; //Zone4
int wifi_led = 13; //i have two LEDS hooked up
int mqtt_led = 15; //i have two LEDS hooked up
//MQTT
WiFiClient net;
MQTTClient client;
unsigned long lastMillis = 0;
//Connect to WiFI and MQTT
void connect();
//Setup pins, wifi, webserver and MQTT
void setup()
pinMode(wifi_led, OUTPUT);
pinMode(mqtt_led, OUTPUT);
Serial.begin(115200);
// set pin modes
pinMode(channe1, OUTPUT);
digitalWrite(channe1, HIGH); //My relay board needs a HIGH output to be OFF and a LOW output to be ON
pinMode(channe2, OUTPUT);
digitalWrite(channe2, HIGH); //My relay board needs a HIGH output to be OFF and a LOW output to be ON
pinMode(channe3, OUTPUT);
digitalWrite(channe3, HIGH); //My relay board needs a HIGH output to be OFF and a LOW output to be ON
pinMode(channe4, OUTPUT);
digitalWrite(channe4, HIGH); //My relay board needs a HIGH output to be OFF and a LOW output to be ON
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
client.begin(server, net);
client.onMessage(messageReceived);
connect();
//Connect to wifi and MQTT
void connect()
delay(100);
digitalWrite(wifi_led, LOW); //turn off WIFI_LED
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
digitalWrite(wifi_led, HIGH); //if wifi is connected, turn on WIFI_LED
Serial.println(WiFi.localIP());
// Loop until we're reconnected
while (!client.connected())
{ digitalWrite(mqtt_led, LOW); //turn off MQTT_LED
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect(mqttDeviceID))
{ digitalWrite(mqtt_led, HIGH); //if MQTT is connected, turn on MQTT_LED
Serial.println("connected");
//once connected to MQTT broker, subscribe command if any
client.subscribe(subscribeTopic1);
client.subscribe(subscribeTopic2);
client.subscribe(subscribeTopic3);
client.subscribe(subscribeTopic4);
client.publish(publishTopic,"ONLINE");
} else {
Serial.print("failed");
Serial.println(" try again in 5 seconds");
// Wait 6 seconds before retrying
delay(6000);
void loop()
// MQTT Loop
client.loop();
delay(10);
// Make sure device is connected
if(!client.connected())
connect();
// Change the state of a relay based on the MQTT Message
void messageReceived(String &topic, String &payload)
Serial.print(topic);
Serial.print("\t");
Serial.println(payload);
String msgString = payload;
if (topic == subscribeTopic1 || topic == subscribeTopic2 || topic == subscribeTopic3 || topic == subscribeTopic4)
if (msgString=="ON")
if (topic == subscribeTopic1)
digitalWrite(channe1, LOW);
client.publish(publishTopic1,msgString);
Serial.println("Turning on Zone 1");
else if (topic == subscribeTopic2)
digitalWrite(channe2, LOW);
client.publish(publishTopic2,msgString);
Serial.println("Turning on Zone 2");
else if (topic == subscribeTopic3)
digitalWrite(channe3, LOW);
client.publish(publishTopic3,msgString);
Serial.println("Turning on Zone 3");
else if (topic == subscribeTopic4)
digitalWrite(channe4, LOW);
client.publish(publishTopic4,msgString);
Serial.println("Turning on Zone 4");
if (msgString=="OFF")
Serial.println("Turning off Zone 1");
Serial.println("Turning off Zone 2");
Serial.println("Turning off Zone 3");
Serial.println("Turning off Zone 4");
and this is my items
Switch SprinklerSystemZone1 "Front Grass Sprinklers" (gIrrigation) [ "Switchable" ] { mqtt=">[broker:SprinklerSystem/Zone1:command:*:default],<[broker:SprinklerSystem/Zone1/Stat:state:default]" , autoupdate="false" }
Switch SprinklerSystemZone2 "Front Garden Sprinklers" (gIrrigation) [ "Switchable" ] { mqtt=">[broker:SprinklerSystem/Zone2:command:*:default],<[broker:SprinklerSystem/Zone2/Stat:state:default]" , autoupdate="false" }
Switch SprinklerSystemZone3 "Back Grass Sprinklers" (gIrrigation) [ "Switchable" ] { mqtt=">[broker:SprinklerSystem/Zone3:command:*:default],<[broker:SprinklerSystem/Zone3/Stat:state:default]" , autoupdate="false" }
Switch SprinklerSystemZone4 "Back Garden Sprinklers" (gIrrigation) [ "Switchable" ] { mqtt=">[broker:SprinklerSystem/Zone4:command:*:default],<[broker:SprinklerSystem/Zone4/Stat:state:default]" , autoupdate="false" }
Switch SprinklerSystemZone1Restart { mqtt=">[broker:SprinklerSystem/Zone1:command:*:default]" , autoupdate="false" }
Switch SprinklerSystemZone2Restart { mqtt=">[broker:SprinklerSystem/Zone2:command:*:default]" , autoupdate="false" }
Switch SprinklerSystemZone3Restart { mqtt=">[broker:SprinklerSystem/Zone3:command:*:default]" , autoupdate="false" }
Switch SprinklerSystemZone4Restart { mqtt=">[broker:SprinklerSystem/Zone4:command:*:default]" , autoupdate="false" }
String SprinklerSystemStatus { mqtt="<[broker:SprinklerSystem/State:state:default]" } //hidden string to be updated depending on status
if this can be of any use
