Hi Vita, Hi All,
I’m trying to setup Openhab 2.4.
The package installs but did not starts.
Can someone give me a tip??
thanks
if I start Manually the following appears:
202 | Installed | 80 | 1.9.0.201901290812 | openHAB Simatic Binding
openhab> bundle:start 202
Error executing command: Error executing command on bundles:
Error starting bundle 202: Could not resolve module: org.openhab.binding.simatic [202]
Unresolved requirement: Import-Package: org.openhab.core.binding
In file openhab-2.4.0\userdata\logs\openhab.log the log is:
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.simatic [202]
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
