fzonno
(Francesco)
March 13, 2019, 8:46pm
21
I’m crazing
Look now
sonoff.items
Switch Interruttore_1_wifi_Sonoff "Interruttore1 WiFi Sonoff" <light> (LR,gLight)
{channel="mqtt:topic:b7bb37dc:Power1"}
Switch LivingRoom_Light "Interruttore2 WiFi Sonoff" <light> (LR,gLight)
{channel="mqtt:topic:b7bb37dc:Power2"}
Interruttore2 WiFi Sonoff works but Interruttore1 WiFi Sonoff no
opus
(Jürgen Baginski)
March 13, 2019, 8:50pm
22
You changed the label(which can be identical) not the name!
You need:
Switch LivingRoom_Light1…
Switch LivingRoom_Light2…
fzonno
(Francesco)
March 13, 2019, 8:56pm
23
Switch LivingRoom_Light1 "Interruttore1 WiFi Sonoff" <light> (LR,gLight)
Switch LivingRoom_Light2 "Interruttore2 WiFi Sonoff" <light> (LR,gLight)
But it is the same
fzonno
(Francesco)
March 13, 2019, 9:00pm
24
The LivingRoom_Light2 works instead LivingRoom_Light1 only turn off
opus
(Jürgen Baginski)
March 13, 2019, 9:06pm
25
Confirm the switching of Power2 works correctly but Power1 does not?
What exactly does Power1 do?
What is the SwitchMode setting for relay1 of your sonoff? (You can check that on the webconsole of the sonoff).
fzonno
(Francesco)
March 13, 2019, 9:13pm
26
YES
If is on i’m able to turn off it.
If is off i’m not able to control
It’s in default setting
fzonno
(Francesco)
March 13, 2019, 9:15pm
27
Look that
Is it possible i must separate the definition of the switch1 and 2?
When i push on the switch1 the log is
2019-03-13 22:25:19.978 [ome.event.ItemCommandEvent] - Item ‘LivingRoom_Light1’ received command ON
2019-03-13 22:25:20.000 [nt.ItemStatePredictedEvent] - LivingRoom_Light1 predicted to become ON
2019-03-13 22:25:20.005 [vent.ItemStateChangedEvent] - LivingRoom_Light1 changed from OFF to ON
2019-03-13 22:25:20.130 [vent.ItemStateChangedEvent] - LivingRoom_Light1 changed from ON to OFF
H102
(CM6.5 H102)
March 13, 2019, 11:34pm
28
fzonno:
Look that
You now need to restart OH, maybe even clean the cache, and see if everything starts working as expected.
fzonno
(Francesco)
March 14, 2019, 5:51am
29
Ok now
I shotdown the raspberry and the sonoff.
I turn on the raspberry.
I open openhab
When i push on switch1 it turns on. When i push again it turns off.
Now i turn on sonoff.
When i push on switch1 it turns on and quickly turns off.
I don’t understand the motivation
Pls tell me what you want i show you…
From Tasmota i van control the switch without problems.
So isn’t it a problem of yhe setting of the firmware
opus
(Jürgen Baginski)
March 14, 2019, 6:14am
30
For me it is not clear what you are saying, what is “Now i turn on sonoff.” ? You connected the sonoff to power? But what reacted on the push of Switch1 before that? Only the openHAB item displayed on a sitemap? Please explain in more detail when only the item reacts and when the actual sonoff switch reacts.
fzonno
(Francesco)
March 14, 2019, 9:50am
31
yes
Before to connect the sonoff to power i touch the switch in openhab and the switch go on and if i touch the switch again it go off.
After i connect the sonoff to power if i touch the switch on openhab the switch go on and automatically go off. This only for the switch 1
No i see both
opus
(Jürgen Baginski)
March 14, 2019, 10:45am
32
And doing the same with switch2 shows normal behaviour?
I do not see any reason for such behaviour🤔
fzonno
(Francesco)
March 14, 2019, 11:25am
33
Yes with the switch2 i have not problems
halloween
(Hallo Ween)
March 14, 2019, 12:26pm
34
Maybe you have misconfigured your sonoff inside tasmota? Can you post all of the webinterface-pages from the sonoff, in which you can edit the settings?
fzonno
(Francesco)
March 14, 2019, 12:39pm
35
I posted it in my first post of this topic
Anyway this evening i tried to reset all again
halloween
(Hallo Ween)
March 14, 2019, 12:44pm
36
You only postet the page with the MQTT settings. But there are more pages, with switch config…
fzonno
(Francesco)
March 14, 2019, 1:22pm
37
This evening i will post all
fzonno
(Francesco)
March 14, 2019, 5:41pm
38
this is my setting of sonoff
When i turn on the switch1 on the console of sonoff i have:
18:46:48 MQT: stat/sonoffSERCAM/RESULT = {“POWER1”:“OFF”}
18:46:48 MQT: stat/sonoffSERCAM/POWER1 = OFF
this is the lod viewer of the openhab:
2019-03-14 18:46:49.150 [ome.event.ItemCommandEvent] - Item ‘LivingRoom_Light1’ received command ON
2019-03-14 18:46:49.158 [nt.ItemStatePredictedEvent] - LivingRoom_Light1 predicted to become ON
2019-03-14 18:46:49.182 [vent.ItemStateChangedEvent] - LivingRoom_Light1 changed from OFF to ON
2019-03-14 18:46:49.241 [vent.ItemStateChangedEvent] - LivingRoom_Light1 changed from ON to OFF
opus
(Jürgen Baginski)
March 14, 2019, 7:21pm
39
That sounds like this power switch is reverted, please check the setting for SwitchMode1 and SwichMode2
