I’m new to openhab and ask you for advice on setup.
According to you it is preferable to use openhab only as a bridge (for example between the control system of lights and amazon alexa) or use it as a true central control system?
Example 1
- (Bridge) buy a complete light control system and use openhab as a bridge between it and amazon alexa
- (central unit) buy switches and lights that can communicate with openhab (konnex) and via a usb / konnex module control the lights via openhab
Example 2
- (Bridge) buy a complete alarm system, complete with control unit and screen and use openhab as a bridge between it and amazon alexa
- (central unit) buy sensors that can be controlled by openhab and define zones and alarms inside openhab
Which is, according to you, the best setup?
