Hi Sihui,
Thank you for your replay, i have made all steps and i’m using the default setting to test demo. But i dont understand whay my account can not connect.
Bests regards.
For 1) you need to setup security in openhab.cfg to external, for 2) you can switch off security (but then you can’t connect to my.openhab.org.
If you are a beginner with openhab I would recommend: don’t deal with my.openhab.org at the beginning, set security to off and connect to your openhab demo locally.
If you have played around a while and need to access openhab from outside your network then deal with my.openhab.org.
Ahh, as I saw just now you tagged your post with openhab2!
I don’t use it , am on version 1.71 production release.
I have therefore no idea if version 2 alpha works the same as version 1 stable regarding auth.
