- Platform information:
- Hardware: ARMv7 Processor rev 2 (v7l) / 512M / 4G SD
- OS: Debian 9.3
- Java Runtime Environment: java version “1.8.0_161”
- openHAB version: 2.2.0-1
- Issue of the topic: OpenHab can read events, but not write with local KNXD
I’m running OpenHab 2.2.0-1 on a Beaglebone with integrated KNX interface and direct bus access I can write events via “knxtool groupswrite” - but not though openhab. OpenHab can read events according to the log, but if i am triggering a write via an item, nothing happens in the log and the switch/light stays off.
My config:
knxd.conf:
“-e 15.0.99 --GroupCache -D -R -T -S --tpuarts-ack-all-group --tpuarts-ack-all-individual --layer2=tpuarts:/dev/ttyS2”
services/knx.cfg
busaddr=15.15.249
type=ROUTER
ignorelocalevents=true
Switch Light_Room_Table "Table Light" <light> (gHLicht) ["Lighting"] { knx = "0/1/8"}
I have the item correct in the sitemap, if i try to switch the light nothing happens.
In addition to the local interface i have an MDT IP Interface (SCN-IP000.02, not the router) and tried to use the tunnel mode - nothing happens.
With the current config, openhab can read events:
2018-01-29 06:34:18.371 [DEBUG] [.binding.knx.internal.bus.KNXBinding] - Received telegram for unknown group address 0/1/9
What am i missing or doing wrong?
Any ideas what i could try?
Thanks very much for your help
