Issue of the topic: I am trying to install the Synology Surveillance Center Binding on Openhab3. When I try to create a Thing in the UI it always fails. Logs show a socket timeout error. I am using http on port 5000, which is the same port the UI uses. Does anyone have any suggestion for troubleshooting or fixing this?
