I’ve fixed it but I do not remember how!
It sounds like the issue is related to authentication. The OpenHab server is showing an error related to invalid basic authentication credentials, which indicates that the app is not sending the correct username and password to the server. It may be best to try using an authentication token instead of a username and password to see if that solves the issue. If this is not working, try to reach the guys from cloud computing consultancy and they should help. I hope this helps and best of luck resolving the issue.
