Hello All,
I would like to know if there is more internal architecture documentation about Openhab Cloud.
On github, we can find a high level architecture schema : GitHub - openhab/openhab-cloud: Cloud companion for openHAB instances.
But I can’t find internal developer documentation about each module.
I’m more particulary interest about the remote proxy acces, secure app acces & authentification / authorization modules.
What I currently try to achieve is to add a more generic incoming redirect UI for binding that need them.
Today some bindings use incoming redirect uri to receive notifications / updates from remote API. This is the case for exemple for HomeConnect and Smartthings binding. For those binding, you generally have to setup a public domain to access your openhab instance.
Openhab cloud can also act as a proxy to your openhab instance using the https://home.myopenhab.org/ uri. What I don’t understand so far is how authentification on this end point is handle in case of non interactive session.
When you acces https://home.myopenhab.org/, openhab is asking for username / password to allow access.
But when this endpoint is called from automation with no http session / context, how could we handle the authentification, and prevent a 401 / UNAUTHORIZED error.
Does we need to setup oauth2 scheme to handle this ? and how ?
Or do we have other more simple solution that I miss ?
Thanks,
Laurent.
