I can still get on locally but as of about 6 hours ago when I try to remotely connect to my server it says on the app it says “Your OpenHab server is offline while the cloud instance is running”…
Looking at my log, my server disconnected from the cloud around the same time, but reconnected 35 minutes later and has been fine ever since. Reconnection doesn’t always happen smoothly, though.
You can force a restart of the cloud connector by going into by going into Settings in MainUI and opening “openHAB Cloud” under "Other Services.
Don’t change any settings; just click the Save (Ctrl+S) button at the top right. You’ll see the restart in your log.
That did it, thanks!
