Hi folks I know there is similar issues on the forums, but I don’t want to restart an old thread just adding to somone elses woes, so I’ll stick mine in here and see if anyone has anything obvious to add.
For your light device its oke, but your roller shutter doesn’t show up.
Roller shutter is not supported by the tag validator, but when you use a [ “Switchable” ] tag the item must show up in the validator.
So the tag is not recognized, check your item again:
Love to get this as part of base package… or maybe just a simple tool you could run on your pi. This way it could check local install first then my openHAB.
Checking local good as sometime my openHAB connection could be a problem. That’s all
quick note: My Google Home mobile App also spits out “Couldn’t update the setting. Check your connection.” sometimes after I authorize GH on myopenhab.org.
Even with this message, the devices will still show up in the GH App. I have done the setup more than 10 times because I was writing a tutorial and I was testing it extensively.
In general: If your cloud connector is set to remote+notify, you Items have been exposed, have received 1 update and as a result: can be displayed on openHAB Cloud - Log in and have proper labels and tags… they will show up in GH App.
Which updated 5 minutes ago, then I reprocessed the auth on 2 different phones with 2 different google users and also 2 different openhab logins to the same openhab install. None of that combo worked. Its such a blackbox though I don’t know where to look other than in the log tails and the items file which offers up no clue.
