i have installed the Openhab-Cloud on my server so far it is up and running but i can’t register an Account and get the following error:
(node:25005) UnhandledPromiseRejectionWarning: MongoError: command count requires authentication
at Connection.<anonymous> (/var/www/vhosts/siam-online.de/openhab.siam-online.de/openhab-cloud/node_modules/mongoose/node_modules/mongodb/lib/core/connection/pool.js:454:61)
at emitTwo (events.js:126:13)
at Connection.emit (events.js:214:7)
at processMessage (/var/www/vhosts/siam-online.de/openhab.siam-online.de/openhab-cloud/node_modules/mongoose/node_modules/mongodb/lib/core/connection/connection.js:368:10)
at Socket.<anonymous> (/var/www/vhosts/siam-online.de/openhab.siam-online.de/openhab-cloud/node_modules/mongoose/node_modules/mongodb/lib/core/connection/connection.js:537:15)
at emitOne (events.js:116:13)
at Socket.emit (events.js:211:7)
at addChunk (_stream_readable.js:263:12)
at readableAddChunk (_stream_readable.js:250:11)
at Socket.Readable.push (_stream_readable.js:208:10)
at TCP.onread (net.js:607:20)
(node:25005) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 25)
if i try to login :
[root@s22930247 openhab-cloud]# node app.js
Option polling duration is not valid. Please refer to the README.
(node:25005) DeprecationWarning: current URL string parser is deprecated, and will be removed in a future version. To use the new parser, pass option { useNewUrlParser: true } to MongoClient.connect.
(node:25005) DeprecationWarning: current Server Discovery and Monitoring engine is deprecated, and will be removed in a future version. To use the new Server Discover and Monitoring engine, pass option { useUnifiedTopology: true } to the MongoClient constructor.
(node:25005) DeprecationWarning: collection.ensureIndex is deprecated. Use createIndexes instead.
MongoError: command find requires authentication
The mongodb is up and running and the account for openhab-cloud is ready and i can login to the database.
here is my config.json:
"system": {
"host": "openhab.siam-online.de",
"port": "443",
"protocol": "https",
"logger" : {
"dir": "./logs",
"maxFiles" : "7d",
"level" : "debug",
"morganOption" : null
"subDomainCookies": false,
"muteNotifications": false
"express":{
"key" : "some express key"
"apn" : {
"gateway": "gateway.push.apple.com",
"cert": "certs/aps/aps_production_cert.pem",
"key": "certs/aps/aps_production_key.pem",
"passphrase": "passphrase"
"gcm" : {
"jid": "++removed++",
"password": "++removed++"
"ifttt" : {
"iftttChannelKey" : "++removed++",
"iftttTestToken" : "++removed++"
"mail": {
"host" : "siam-net.de",
"port" : 465,
"user" : "myopenhab@siam-net.de",
"pass" : "++removed++"
"mongodb": {
"hosts": ["127.0.0.1"],
"db": "openhab-cloud",
"user" : "openhab-cloud",
"redis": {
"host": "127.0.0.1",
"port": "6379"
"mailer": {
"port": 465,
"secureConnection": true,
"user": "myopenhab@siam-net.de",
"password": "++removed++",
"from": "openHAB Cloud <myopenhab@siam-net.de>"
"legal": {
"terms" : "",
"policy": ""
"registration_enabled": true
and here the Startup information from Openhab:
2020-08-05 12:00:56:5656 info: openHAB-cloud: Backend service is starting up...
2020-08-05 12:00:56:5656 info: openHAB-cloud: Backend logging initialized...
2020-08-05 12:00:57:5757 info: openHAB-cloud: Initializing XMPP connection to GCM
2020-08-05 12:00:57:5757 info: openHAB-cloud: Connecting to Redis at 127.0.0.1:6379
2020-08-05 12:00:58:5858 info: openHAB-cloud: Mailer will emulate sending in development environment
2020-08-05 12:00:58:5858 info: opneHAB-cloud: Trying to connect to mongodb at: mongodb://127.0.0.1/openhab-cloud?poolSize=100
2020-08-05 12:00:58:5858 info: openHAB-cloud: Scheduling a statistics job (every 5 min)
2020-08-05 12:00:58:5858 info: openHAB-cloud: IFTTT is configured, app handling IFTTT capabilities...
2020-08-05 12:00:58:5858 info: openHAB-cloud: express server listening on port 3000
2020-08-05 12:00:58:5858 info: openHAB-cloud: Redis is ready
2020-08-05 12:00:58:5858 info: openHAB-cloud: Successfully connected to mongodb
2020-08-05 12:00:59:5959 info: openHAB-cloud: GCM XMPP connection is online
At Startup, it seems the connection to mongo is ok but why i get this error when I will setup an account or if i try to login to openhab cloud?
Can somebody point me in the right direction ?
Andy
