As a relative newbie to OpenHAB, I’ve managed to get some basic automation up & running, and connected it successfully to myopenHAB. At face value, it appears to work OK, but on looking at the logs (openhab.log), it is regularly having problems connecting to the OpenHAB cloud. Log extract below
OpenHAB is running on a Windows 10 machine, with Zulu Java, with a hard-wired connection to the router (which is 4G LTE)
Any ideas gratefully received
Log extract:
2020-02-08 19:25:25.214 [ERROR] [io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: {}
io.socket.engineio.client.EngineIOException: websocket error
at io.socket.engineio.client.Transport.onError(Transport.java:63) [bundleFile:?]
at io.socket.engineio.client.transports.WebSocket.access$400(WebSocket.java:24) [bundleFile:?]
at io.socket.engineio.client.transports.WebSocket$1$5.run(WebSocket.java:107) [bundleFile:?]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [bundleFile:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_242]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_242]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_242]
Caused by: java.net.SocketException: Network is unreachable: recv failed
at java.net.SocketInputStream.socketRead0(Native Method) ~[?:1.8.0_242]
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) ~[?:1.8.0_242]
at java.net.SocketInputStream.read(SocketInputStream.java:171) ~[?:1.8.0_242]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_242]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:1.8.0_242]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:1.8.0_242]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:975) ~[?:1.8.0_242]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:933) ~[?:1.8.0_242]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) ~[?:1.8.0_242]
at okio.Okio$2.read(Okio.java:139) ~[?:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[?:?]
at okio.RealBufferedSource.request(RealBufferedSource.java:67) ~[?:?]
at okio.RealBufferedSource.require(RealBufferedSource.java:60) ~[?:?]
at okio.RealBufferedSource.readByte(RealBufferedSource.java:73) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.readHeader(WebSocketReader.java:113) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.processNextFrame(WebSocketReader.java:97) ~[?:?]
at okhttp3.internal.ws.RealWebSocket.loopReader(RealWebSocket.java:262) ~[?:?]
at okhttp3.internal.ws.RealWebSocket$2.onResponse(RealWebSocket.java:201) ~[?:?]
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:141) ~[?:?]
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32) ~[?:?]
I seem to recall seeing a sticky post yesterday (Feb 8) about maintenance being performed (sorry I don’t have the particulars of the post because I didn’t read it). As your log entry is from yesterday, could the maintenance be the cause of your issue?
Mark - thanks for the reply. It’s been going on for quite a few days, so don’t think it’s a openhab cloud maintenance issue - unless they take it down daily?
Log was full of the following error, repeated many times. Pi 4 had slowed to a crawl. After reading through a few threads including this one, I’m guessing that the Chrome window with myopenhab.org open that had perhaps timed out. Was the problem. Closed it and rebooted. So far, hasn’t repeated.
at java.net.SocketInputStream.read(SocketInputStream.java:204) ~[?:1.8.0_252]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_252]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:1.8.0_252]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:1.8.0_252]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:990) ~[?:1.8.0_252]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:948) ~[?:1.8.0_252]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) ~[?:1.8.0_252]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:345) ~[?:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:217) ~[?:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:211) ~[?:?]
at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:189) ~[?:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:75) ~[?:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[?:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:45) ~[?:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[?:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:93) ~[?:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[?:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120) ~[?:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:185) ~[?:?]
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:135) ~[?:?]
... 3 more
2020-06-30 08:33:19.313 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 6f19531e-eb40-4e9b-b06f-b0368dca3c2a, base URL = http://localhost:8080)
