I have installed OpenHAB 1.8.3 on my Synology DS413j, which installed fine with no issues. I even managed to view the demo files on both browser and iPhone, including creating the symbolic links for the addons and configurations folders.
I have set up the openhab.cfg file to include the following:
security:option=EXTERNAL
myopenhab:localport:8081
security:netmask=192.168.0.0/24
The public/OpenHAB folder on my NAS has the correct permissions for the OpenHAB daemon user set up.
When I took a look at the openhab.log file, I noticed the localhost value as follows:
13:16:33.658 [INFO ] [.myopenhab.internal.MyOHClient:224 ] - Connected to my.openHAB service (UUID = , local base URL = http://localhost:8080)
Given that my OpenHAB is running on my Synology NAS, localhost is clearly wrong and so is the port. Would I be right in thinking this is the cause? If so, has anyone come across this at all and more importantly fixed it.
Actually under normal circumstances localhost:8080 (unless you changed the default port) is correct. The my.openhab binding acts as a proxy between my.openhab.com and your openHAB’s REST (i.e. HTTP) API. The binding actually makes the same calls to openHAB as your Sitemap does, only because it is a binding it knows it is on the same host that openHAB is running on. This is why you need to set security to EXTERNAL; the binding can’t supply a username and password to the REST API.
However, you are using the localport option so it should be connecting to localhost:8081. So I’ve no idea what is going wrong but suspect that is a problem.
