I’ve got the current rules in my Openhab which basically just sends my phone an alert if I have left the gate open after 10 minutes.
RULES FILE:
//Gate Sensor
rule "Gate Sensor"
Item MGateSensor1 changed
if(Notifications.state == ON) {
if (triggeringItem.state == OPEN) Gate_Timer.sendCommand(ON) // Start timer
else Gate_Timer.postUpdate(OFF) // Cancel the timer
rule "Gate Timer"
Item Gate_Timer received command OFF
sendBroadcastNotification("ALERT: Gate has been OPEN for 10 minutes!")
ITEMS FILE:
Switch Gate_Timer { expire="10m,command=OFF" }//
I basically want the system to send me a notification once the gate has been closed, but only after it has send a message saying it’s been left open.
EG. 0-9 mins = no notification
10 mins = notification that the gate has been left open
more than 10 mins = notification only when the gate get’s closed.
Contact door
Contact doorSendOpenMsg {expire="10m,state=CLOSED"}
rule "door"
Item door changed
doorSendOpenMsg.postUpdate(door.state)
rule "doorsendOpenMsg CLOSED"
Item doorSendOpenMsg changed to CLOSED
if (door.state == OPEN) {...}
first of all: please use Code fences (one of the Icons on the top Right) - makes the Code more readable…
second: you are not sooo much away. If I understand correctly, you only want a notification, if you left the gate open for more than 10mins?
so, basically what you did was:
Setting upt the Gate_Timer Switch with a 10min. expire time (good!)
writing a rule “Gate Sensor” which sets the time to ON, if the Gate is open (good!)
you won’t Need the OFF though…
writing a rule “Gate Timer” which handles the notification (good!) - but it Always sends it, if the Gate_Timer receives OFF
notice, I moved the “notification” clause to the sendnotification-rule, as it is better to use it just before that.
notice also, that you don’t need to change the Timer to OFF - but you should check, whether the gate is OPEN and the Timer just went OFF.
so - let’s do it:
item:
Switch Gate_Timer { expire=“10m,command=OFF” } // leave that! It tells the timer to switch OFF after 10mins
Gate Sensor rule
rule "Gate Sensor"
Gate Timer rule
rule "Gate Timer"
if (Notifications.state == ON && MGateSensor1.state == OPEN) {
// I guess you use the Notificatins-variable to surpess notifications - so better to place it in front of notifications!
// So, basically, if Notifications are ON *and* the Gate ist OPEN *and* Timer went OFF, then send notifications
Thank’s for your reply! My current code / rules works fine with the notifications - I simply want a notification to tell me once the gate has been closed. Let me try clarify. There is basically 2 possible scenarios that could occur. Gate being closed before 10 minutes or gate being closed after 10 mins.
Scenario 1 //
00:00 - Gate Opens / no notification (done)
00:10 - Notification sent out alerting gate been left open (done)
00:15 - Gate gets closed manually / Send out notification alerting that the gate has been closed (what I’m after)
Scenario 2 //
00:00 - Gate Opens
00:05 - Gate gets closed / do not send out any notifications
Hope this helps! My current setup for the rules works just without the closed notification.
Would it be possible to simply add an if statement after my
sendBroadcastNotification(“ALERT: Gate has been OPEN for 10 minutes!”)
var openMsgHasSend = false
rule "door"
Item door changed
if (door.state == CLOSED && openMsgHasSend) {
sendBroadcastNotification(“INFO: Gate has been CLOSED!”)
openMsgHasSend = false}
openMsgHasSend = true}
var Timer fronddoorTimer = null
var alarm = false
rule "Gate Sensor open"
Item MGateSensor1 changed from CLOSED to OPEN
if(fronddoorTimer === null ) {
fronddoorTimer = createTimer(now.plusMinutes(10), [|
alarm = true
rule "Gate Sensor close"
Item MGateSensor1 changed from OPEN to CLOSED
if(fronddoorTimer !==null) fronddoorTimer.cancel() //Terminate timer if door is closed before the timer ends
if (alarm === true) {
sendBroadcastNotification(“ALERT: Gate has been CLOSE!”)
alarm = false
