openHAB Designer dont work
I´m ussing Raspberry Pi (old version) then I follow the instruction and the runtime is woking fine, I have the demo and is working then I try to open Designer but nothing happens, I copy and rename the .cfg file, still nothing happend.
Thanks in advance
You need to perform step 3 in “Installing the openHAB designer (optional)” on this “Getting Started” page:
http://www.openhab.org/getting-started/index.html
I have the same problem. When I try to start the designer in a Ubuntu desktop environment nothing happens. When I try to start it from the command line it results in the following message:
./openHAB-Designer: 1: ./openHAB-Designer: Syntax error: “(” unexpected
What java runtime is required for the openHAB Designer? The openHAB Runtime runs smoothly on OpenJDK 8. Will the openHAB Designer and the openHAB Runtime require different java versions?
This almost looks like a corrupted file … I would try to download the designer again and reinstall it.
hi all
just a question. I have tried to follow to “designer guide” but still when i start the designer and tro to open the config folder, its says that the folder is not right and I have to find the right one… anyone who can help me… im just testing right now, so everything is running on windows
Peter
Most common problem is, you need to have the openhab_default.cfg file in place, not only your individual openhab.cfg.
Then in designer open your folder /etc/openhab and it should work.
Good luck.
Perfect… it worked… thanks
Hi, I’ve downloaded the 64-bit and the 32-bit version, and both versions of the new 1.8.0 release. All versions resulting in the same error: Syntax error: “(” unexpected.
I’ve also tried the Oracle 8 JDK now instead of the OpenJDK. Also without success and the same result. Does somebody have any suggestions?
Sorry, not me, I’m using Designer on Windows, not on Ubuntu.
Hi, I’m having what I think is a similar issue.
I’ve manually installed everything on my mac running 10.9.5.
I created the files structure \opt\openhab.
Designer doesn’t recognize it as a valid folder.
I have no clue what is going on. I even retired to install using all the Linux commands using brew since the mac doesn’t have some of the Linux commands.
If you need additional information let me know. Thanks in advance of any and all help.
[quote=“The4thIcon, post:11, topic:3125, full:true”]
Designer doesn’t recognize it as a valid folder.[/quote]
You need to open your configuration folder, not the openhab folder itself.
Never got the designer to work because of the annoying syntax error. Configured openhab manually by editing text files. Next obstacle was changing the color of my Aeon Labs Light Bulb. Isn’t possible in openhab 1. So I removed everything and installed openhab 2, manually. It runs in a terminal session. Now I want to install it as a service using the command openhab:install-service. Starting the runtime now results in the same darn syntax error: Syntax error: “(” unexpected.
Who can please help me getting rid of these show stopping syntax errors?! It takes away all my pleasure in experimenting with openhab. And I’m seriously thinking of moving back to Domoticz because I’m not a java expert (yet).
In another thread you mention your are on ODROID Hardware.
Maybe you should open a new topic with a more specific header, something like “Not able to install OH2 on Odroid as a service”.
Only a few people here are on a Odroid and in this way you can better get their attention.
Good luck, don’t give up, most people love OH :slightly_smiling:
Thanks! I already played with these thoughts as I wrote it down. I will open a new thread and ask some relevant questions there.
I tried installing the designer on Ubuntu last night, and after updating the ini file with the following it started working
-Dorg.eclipse.swt.browser.DefaultType=mozilla to openHAB-Designer.ini
However, whenever I attempt to connect to my openhab.cfg file, it tells me that it can’t use it because of
Cannot create linked resrouce '/config/config'. The parent resource is not accessible
Both the openhab.cfg and openhab_default.cfg are in the same folder, but it should be noted that both are under /etc/ and not /opt/ as indicated in the manual install instructions
The items from my item config are showing up as expected.
I should note that I used the apt-get install method, not the manual method. If that’s the source of my headaches, then I can move to manual and remove the openHAB apt-get package.
I installed the designer as explained in getting started on my raspberry pi (model A) in a separate folder at the /opt/-folder.
When trying to start openhab-designer it looks like its not there!?
pi@raspberrypi:/opt/openHAB-designer $ openHAB-Designer
-bash: openHAB-Designer: opdracht niet gevonden
this seems a siple problem but don’t know where to look.
other question: can I run openhab designer on my laptop while the raspberry is hosting the openhab runtime/addons
Yes, you need to setup a samba share, take a look here:
I don’t think that is a good solution: the Pi model A has, what I have read, not enough cpu power to run openhab designer … but I have never tried it …
ok thx, will try tomorrow, will post feedback on that cpu power :wink:
