Is there any option for the openhab-designer.ini file to forcefully use a certain Java version? I have multiple Java versions installed (among others, a special one inside the openhab designer installation directory) and I would like to force openhab designer to use that particular one.
If I remember correctly, you can create a sub folder called jre in the designer root folder and put the java jre you are willing to use inside.
Well, that did the trick! Thank you very much for this information. This way, I can isolate the specific Java version needed for openHAB.
A pity this information is not (or not easily) available through the openHAB documentation…
Where did you find this information anyway, if I may ask?
To be honest, I can’t remember where I have this information from…
But good to hear that you have sorted your issue.
