Warning: The unit file, source configuration file or drop-ins of openhab2.service c● openhab2.service - openHAB2 instance, reachable at http://openHABianDevice:8080
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset Drop-In: /etc/systemd/system/openhab2.service.d
└─override.conf
Active: activating (start-post) (Result: exit-code) since Sat 2020-12-19 09:26:3 Docs: https://www.openhab.org/docs/ https://community.openhab.org
Process: 9256 ExecStartPre=/bin/bash -c /usr/bin/find ${OPENHAB_CONF} -name "*.ru Process: 9258 ExecStart=/usr/share/openhab2/runtime/bin/karaf ${OPENHAB_STARTMODE Main PID: 9258 (code=exited, status=1/FAILURE); Control PID: 9259 (sleep)
Tasks: 1 (limit: 995)
CGroup: /system.slice/openhab2.service
└─9259 /bin/sleep 120
Dec 19 09:26:38 openHABianDevice systemd[1]: Starting openHAB2 instance, reachable Dec 19 09:26:39 openHABianDevice systemd[1]: openhab2.service: Main process exited,
– The job identifier is 1637 and the job result is done.
Dec 19 09:50:26 openHABianDevice systemd[1]: Stopped openHAB2 instance, reachable a-- Subject: A stop job for unit openhab2.service has finished
– Defined-By: systemd
– Support: https://www.debian.org/support
– A stop job for unit openhab2.service has finished.
– The job identifier is 1569 and the job result is done.
Dec 19 09:50:26 openHABianDevice systemd[1]: Starting openHAB2 instance, reachable – Subject: A start job for unit openhab2.service has begun execution
– A start job for unit openhab2.service has begun execution.
– The job identifier is 1569.
Dec 19 09:50:27 openHABianDevice karaf[1865]: java command not found
Dec 19 09:50:27 openHABianDevice systemd[1]: openhab2.service: Main process exited,-- Subject: Unit process exited
– An ExecStart= process belonging to unit openhab2.service has exited.
I just saw that Java could not be found… But I didn’t deinstalled it
sudo openhab-cli start
A systemd service configuration exists…
Use ‘sudo /bin/systemctl start openhab2.service’ to start an openHAB service
Launching an instance in this terminal…
Launching the openHAB runtime…
