I’m running Ubuntu 15.04, with the following java version:
java version "9-ea" Java(TM) SE Runtime Environment (build 9-ea+95-2015-12-02-052152.javare.3968.nc) Java HotSpot(TM) 64-Bit Server VM (build 9-ea+95-2015-12-02-052152.javare.3968.nc, mixed mode)
I followed the instructions and installed Openhab in /opt, and installed the demo package. However, Openhab will not launch. When I use, start.sh, I only see " Launching the openHAB runtime…" and never proceed further.
Running “netstat -apn | grep 8080” never shows any process binding to that port.
It is still running, since the command “ps aux | grep java” brings up the following:
java -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=8080 -Djetty.port.ssl=8443 -Djetty.home=. -Dlogback.configurationFile=configurations/logback.xml -Dfelix.fileinstall.dir=addons -Dfelix.fileinstall.filter=.*.jar -Djava.library.path=lib -Djava.security.auth.login.config=./etc/login.conf -Dorg.quartz.properties=./etc/quartz.properties -Dequinox.ds.block_timeout=240000 -Dequinox.scr.waitTimeOnBlock=60000 -Dfelix.fileinstall.active.level=4 -Djava.awt.headless=true -jar server/plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar -console
Running the ./start_debug.sh brings up the following, but goes no further:
./start_debug.sh
Launching the openHAB runtime in debug mode…
Listening for transport dt_socket at address: 8001
Any ideas?
