Hi
Test Setup: Enocean Switch, Enocean Sniffer (USB 300 DB), OpenHAB and the Enocean Receiver.
Project Aim: The aim of the Project is to send a RPS command whenever the Enocean Switch is Pressed and Released.
Process Flow:
- Press the Enocean Switch and send RPS command 0x30 (HEX) to the OpenHAB — “PASS”
- OpenHAB should be able to receive the RPS command 0x30 (HEX) through Enocean_Sniffer (USB 300 DB) — “PASS”
- OpenHAB should be able to Transmit/Send the RPS command to the Enocean Receiver (Actuator) in order to operate it — “FAIL”
I feel like, I must be missing something-somewhere while configuring the Enocean Receiver. Please find below the Items as well as the Rules configurations. Also please let me know, if You need any other configurations as well.
- Enocean.items configuration is as follows:
Switch BLIND_UP () {enocean="{id=FF:A8:FF:80, eep=F6:02:01, channel=A, parameter=O}"}
Switch BLIND_DOWN () {enocean="{id=FF:A8:FF:80, eep=F6:02:01, channel=A, parameter=I}"}
Switch O_UP_CH_A () {enocean="{id=00:2B:FC:75, eep=F6:02:01, channel=A, parameter=O}"}
Switch I_DOWN_CH_A () {enocean="{id=00:2B:FC:75, eep=F6:02:01, channel=A, parameter=I}"}
Switch O_UP_CH_B () {enocean="{id=00:2B:FC:75, eep=F6:02:01, channel=B, parameter=O}"}
Switch I_DOWN_CH_B () {enocean="{id=00:2B:FC:75, eep=F6:02:01, channel=B, parameter=I}"
- Enocean.rules configuration is as follows:
rule "Initialize light states"
System started
sendCommand(BLIND_UP, ON)
rule "BLIND CH-A UP-RUNNING"
Item O_UP_CH_A changed to ON
rule "BLIND CH-A UP-STOP"
Item O_UP_CH_A changed to OFF
sendCommand(BLIND_UP, OFF)
rule "BLIND CH-A DOWN-RUNNING"
Item I_DOWN_CH_A changed to ON
sendCommand(BLIND_DOWN, ON)
rule "BLIND CH-A DOWN-STOP"
Item I_DOWN_CH_A changed to OFF
sendCommand(BLIND_DOWN, OFF)
rule "BLIND CH-B UP-RUNNING"
Item O_UP_CH_B changed to ON
rule "BLIND CH-B UP-STOP"
Item O_UP_CH_B changed to OFF
rule "BLIND CH-B DOWN-RUNNING"
Item I_DOWN_CH_B changed to ON
rule "BLIND CH-B DOWN-STOP"
Item I_DOWN_CH_B changed to OFF
NOTE:
BLIND_UP = Blinds (Enocean Receiver, ID = FFA8FF80)
BLIND_DOWN = Blinds (Enocean Receiver, ID = FFA8FF80)
O_UP_CH_A = Enocean Switch (Channel-A, UP Direction, ID = 002BFC75)
I_DOWN_CH_A = Enocean Switch (Channel-A, DOWN Direction, ID = 002BFC75)
O_UP_CH_B = Enocean Switch (Channel-B, UP Direction, ID = 002BFC75)
I_DOWN_CH_B = Enocean Switch (Channel-B, DOWN Direction, ID = 002BFC75)
Please let me know, in case of any further Query.
Awaiting for Your Valuable Suggestions/Guidance…
Thank You.
