Just wondered if anyone have tried to use SmartVISU in combination with OH? If you have a driver for smartVISU to connect to OH, I would really appreciate if you would consider to share it with me.
Best regards
Chris
Best regards
Chris
looks like this has started now: https://github.com/Martin-Gleiss/smartvisu/pull/57
Cheers
Chris
was somebody able to connect smartvisu to openhab2 items? I cannot find any howto. I tried it by myself but I am getting only errors after I open an smartvisu page which contains oh2 items. Also OH2 shows erros inside the log:
Caused by: java.io.IOException: Datenübergabe unterbrochen (broken pipe)
at sun.nio.ch.FileDispatcherImpl.write0(Native Method)[:1.8.0_101]
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47)[:1.8.0_101]
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93)[:1.8.0_101]
at sun.nio.ch.IOUtil.write(IOUtil.java:65)[:1.8.0_101]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471)[:1.8.0_101]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:170)[73:org.eclipse.jetty.io:9.2.14.v20151106]
⦠10 more
Had somebody more luck and got it running?
I tried following:
Smartvisu webpage:
OH2 item def:
Switch Licht_Switch_SZ_Iris āIrisā gHueLights_Alle_Switch,gHueLights_Schlafzimmer_Switch) { channel=āhue:0200:00178816e03f:9:colorā }
But without success
The SmartVisu has a very nice UI⦠just had a problem with it together with smart home.py since it loses the connection pretty often to the UI⦠hopefully this is solved if this driver gets working
