Platform information: Synology DS218j
- Java Runtime Environment: Java 11
- openHAB version: 3.0/2.5/2.3
Issue of the topic:
Trying to install openHAB on my Synology drive and I continue to get the following error:
2021-10-10:20:59:54
Set instance variables…
public: false
smarthome: false
home: true
TMPFS: false
Z-Wave: false
port: 8080
port: 8443
tmp: /volume1/@tmp
share: /var/services/homes
oh: /var/services/homes/openhab
backup: -backup-202110
done
User that exec the Installation
root
Start preupgrade…
Stop server
Remove tmp, cache and runtime dirs
Remove openHAB system files
Create backup
Save symbolic link folders
ERROR:
Update failed. Link folder ‘’ could not be found.
Please try again or contact the github contributors.
Please post configurations (if applicable):
- Items configuration related to the issue
I’ve tried selecting /public/OpenHAB and /var/services/homes/openHAB folder. No different. I’ve placed conf, addons, and userdata subdirectories inside of the openHAB folders, no change.
If logs where generated please post these here using code fences:
#### S T A R T - o p e n H A B S P K ####
2021-10-10:20:59:54
Set instance variables...
public: false
smarthome: false
home: true
TMPFS: false
Z-Wave: false
port: 8080
port: 8443
tmp: /volume1/@tmp
done
root
Start preupgrade...
Stop server
Create backup
ERROR:
Update failed. Link folder '' could not be found.
