openHAB - Filtering event logs
I think I managed to figure something out. I could not get the filtering approach to work to filter out some recurring warning messages in the openhab log. I tried setting the root logger to ERROR and it took care of it. Not ideal but will avoid flooding my logs for now.
I am having the same problem trying to filter out Errors from the Openhab.log
This tutorial only seems to be for Events.log
I just want to stop these messages appearing in the openhab.log
> 2019-02-01 14:52:10.081 [ERROR] [sciani.connector.MyHomeJavaConnector] - Monitor connection problem. Attempting retry 2.
In the file:
/srv/openhab2-userdata/etc/org.ops4j.pax.logging.cfg
There is a section for each log file
Modify the section for openhab.log the same way as the examples above
This is what I’ve tried but it does not seem to work? Am I in the correct section
Rolling file appender
log4j2.appender.out.type = RollingRandomAccessFile
log4j2.appender.out.name = LOGFILE
log4j2.appender.out.fileName = ${openhab.logdir}/openhab.log
log4j2.appender.out.filePattern = ${openhab.logdir}/openhab.log.%i
log4j2.appender.out.immediateFlush = true
log4j2.appender.out.append = true
log4j2.appender.out.layout.type = PatternLayout
log4j2.appender.out.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j2.appender.out.policies.type = Policies
log4j2.appender.out.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.out.policies.size.size = 16MB
#log enhancement
log4j2.appender.out.filter.btcino.type = RegexFilter
log4j2.appender.out.filter.btcino.regex = = .*Monitor connection problem*
log4j2.appender.out.filter.btcino.onMatch = DENY
log4j2.appender.out.filter.btcino.onMisMatch = ACCEPT
This is yours:
This is the example:
log4j2.appender.event.filter.smappee.regex = .*power_smappee.*
See the difference?
Yes I tried that one before but I assumed that is just filtering from the event.log because it did not work
And that?
ah!!
ah!! indeed… Does is work?
just testing!
Yes this works thanks for your help! I’m still not too clear on the regex pattern matching - I can’t find a good site that explains exactly how it works with wildcards but for now this is fine.
#log enhancement
log4j2.appender.out.filter.btcino.regex = .*connection problem.*
I find this site to be of great help in testing regex. Put in your regex pattern and then copy/paste a chunk of your event.log. Note that I’m not sure how much you can paste into the text box.
I can’t get the log4j2 regex filter work on my events.log file. I’m running OH 2.5.0 M1 on openhabian.
I added the following 4 lines at the end of /var/lib/openhab2/etc/org.ops4j.pax.logging.cfg
log4j2.appender.event.filter.uselessjunk.type = RegexFilter
log4j2.appender.event.filter.uselessjunk.regex = .*(Astro_(Sun|Moon|Civil|Nautic|Astro|Noon|Morning|Evening)|Wx_OWM_(Current|Forecast)|openweathermap_(weather_and_forecast|uvindex)).*
log4j2.appender.event.filter.uselessjunk.onMatch = DENY
log4j2.appender.event.filter.uselessjunk.onMisMatch = ACCEPT
I tested the regex online and it shows the matches on the sample input I provided.
When I restart openhab2, then I see the event log lines matching the regex are still logged in /var/log/openhab2/events.log.
What am I doing wrong?
EDIT: it now works
Hi, please can someone help me? MY configuration is not working:
Here are my errors/warnings i want to remove from openhab.log:
2019-03-06 15:51:07.240 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '167310.0' could not be sent to the KNX bus using datapoint 'command DP 4/3/1 HeatPump_Stromzaehler, DPT main 0 id 12.001, low priority' - retrying one time: 12.001 Unsigned count: wrong value format: 167310.0
2019-03-06 15:51:07.240 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Value '167310.0' could not be sent to the KNX bus using datapoint 'command DP 4/3/1 HeatPump_Stromzaehler, DPT main 0 id 12.001, low priority' - giving up after second try: 12.001 Unsigned count: wrong value format: 167310.0
And here is my pax4j-logging-config:
################# KNX Fehler ausbelenden ###########
# Filtering Rules
log4j2.appender.event.filter.KNXremove.type = RegexFilter
log4j2.appender.event.filter.KNXremove.regex = .*could not be sent to the KNX bus using datapoint.*
log4j2.appender.event.filter.KNXremove.onMatch = DENY
log4j2.appender.event.filter.KNXremove.onMisMatch = ACCEPT
If you want to filter openhab.log, don’t you want this to be
log4j2.appender.out.filter.KNXremove.type = RegexFilter
log4j2.appender.out.filter.KNXremove.regex = .*could not be sent to the KNX bus using datapoint.*
log4j2.appender.out.filter.KNXremove.onMatch = DENY
log4j2.appender.out.filter.KNXremove.onMisMatch = ACCEPT
I changed event to out, but the errors and warnings still appear in my openhab.log.
Since when does it not work for you (anymore). Maybe I currently have the same problem:
Hmm. Then I’m not sure what’s going on.
I have the same problem. I guess I have the right logging settings (see below), but without effect. Actually the logs don’t even confirm that the logfile has been re-read, but I’m not sure if that is logged (if not, it should).
log4j2.appender.event.filter.CurrentCost.type = RegexFilter
log4j2.appender.event.filter.CurrentCost.regex = .*CurrentCost_xml. (there is a star after the point, but it is filtered out by the editor…)
log4j2.appender.event.filter.CurrentCost.useRawMsg = false
log4j2.appender.event.filter.CurrentCost.onMatch = DENY
log4j2.appender.event.filter.CurrentCost.onMisMatch = ACCEPT
Only thing that could be are the camel case. Try currentcost instead of CurrentCost.
It’s unfortunately not.
