I am an end user, and will not contribute here with coding or documentation. If I have to pay for the job done by others I gladly do. since I like openhab2 (once its well configured)
WHat I can do is testing, and reporting my user experience. If you all don’t like my open thoughts, I can surely shut up. No problem
I believe everyone in this community consider themselves as the end users. Including Maintainers, OH/ESH developers, casual committers and regular posters.
No one has said you are not entitled to your own opinion. I think the point being made is that you should not expect a lot of help from people that freely give of their time to support the project if you are not first willing to make an attempt to help yourself.
There is no need to read the docs in it’s entirety. If you read some of the getting started sections and the pieces relevant to the devices you are using you should be off to a pretty good start. Searching the Community and Google will help fill in the blanks. If something is still unclear or you run into problems, I’m willing to bet people here in the Community would be more than willing to help at that point.
Does the documentation need some work? Sure. I think the same thing could be said for the vast majority of open source projects. When there are thousands of users but only a handful of contributors it is hard to keep up. Especially when you consider how complex and rapidly evolving something like OH is.
I frankly don’t expect users with a low to average computer experience to be successful with any home automation system in the first place. Home automation is hard. It’s complicated. And it takes a good deal of dedication and willingness to learn in order to get through it.
If you are unwilling to put in that sort of work then you might be happier with a less capable but slightly easier to use a commercial solution like Vera or Wink.
We welcome any suggestions you might offer. We would really welcome any contributions you may want to make.
But I suspect the structure of the docs is not the real problem. The real problem is this is really complicated stuff and no amount of restructuring of the docs is going to change that. But if I’m wrong we welcome your suggestions.
If you are unwilling to actually contribute to the docs then I’m afraid to say, as with any opensource project, your thoughts and observations will likely never be implemented. There is no leader who says “hey you, go write that doc.” If you are unwilling to contribute yourself you can only hope that someone will be willing to pick up your request and implement it for you. And of course, all of us volunteers have our own things we want to implement or write. You might be able to entice someone to do so for you through the BountySource link kuba posted but you are still dependent on someone deciding to pick up the task and do it.
And so far your observations are “this is complicated” and “the docs need to be restructured.” Neither of these are actionable observations. You make no suggestions about what to change or how to change it. So far these are mere complaints; we can’t do anything with them.
Great tool, I wish to understand how to add some components that are not automatically added (for example Hue color, or motion sensor time of trigger).
Not sure if is possible to add script (sequence of commands) and rules/automation
Great work!
I have just few questions. Can we also control devices action from this like turning on/off and getting information from sensors(heating).
also if you can guide if I have to add any enocean wireless can that be done. Will it also manage its configuration
