{openhab.home} for OH2
Which one is it for OH2 installed from deb as there quite a lot of dirs created
See here: http://docs.openhab.org/installation/apt.html (go down to File locations)
Well if {openhab.home} is /usr/share/openhab2/
Where shoul i put the file for the action playSound(“clock_gong.wav”)
As having an item in /usr/share/openhab2/sounds
Still renders an error no matter if full or just a file name are given
Cannot play sound '/usr/share/openhab2/sounds/clock_gong.wav': runtime/sounds/usr/share/openhab2/sounds/clock_gong.wav (No such file or directory)
Or
What’s your definition? the path is doubled…
Well in the rules now i have
playSound("clock_gong.wav")
But as i’ve mentioned i also tried a full path definition with no luck
2016-06-26 10:20:02.320 [ERROR] [.openhab.io.multimedia.actions.Audio] - Cannot play sound 'clock_gong.wav': runtime/sounds/clock_gong.wav (No such file or directory)
And it is there
xxx@xxx:/usr/share/openhab2/runtime/sounds $ ls -l
total 3872
 -rwxr-xr-x 1 openhab pi      3860774 Apr  3 18:38 clock_gong.wav
 -rw-r--r-- 1 openhab openhab  102399 Jan 16 00:04 doorbell.mp3
Openhab is in the audio group
Does it play the doorbell.mp3?
playSound("doorbell.mp3")
nope
2016-06-26 18:04:00.048 [ERROR] [.openhab.io.multimedia.actions.Audio] - Cannot play sound 'doorbell.mp3': runtime/sounds/doorbell.mp3 (No such file or directory)
hmmm… that’s very strange. At least the demo should work flawless, so I guess, there has something gone wrong when setting up OH2 through apt-get. Maybe an apt-get purge openhab2-online (or -offline) and reinstall OH2 would solve this issue.
Did you manage to find a solution?
I moved away from the apt install hoping one of the latest builds would address the problem, but I still cannot get it working, although the file is there and permissions are fine.
Well currently utilising exec action together with aplay.
