Change directories to /opt/FireMotD then sudo ./FireMotD -I -v like this:
cd /opt/FireMotD$ sudo ./FireMotD -I -v
@H102 yes, you can access multiple actually. Press alt and f1-4 possibly through 6.
I usually have multiple going to monitor things. give it a tryâŠ
Good to know and will give it a try.
the milight ibox wonât pink upon automatic on the log it say error installing and installing how do I add it in as mi light I got openhab working on pi now works with Samsung tvs etc
can you please address this about box ml light
Sorry no experience with that binding. You can search this forum for similar problems or check github for issues https://github.com/openhab/openhab2-addons/issues
If you canât find a solution it may be best to open a new topic for mil light problems.
If you search on openhab itâs there called mi light bilding and other people have talked about it on this form under ml light
Can you post the error logs to help troubleshoot the issue?
I did not ask that the older mi light box openhab picks up the new inbox does not is there a setting differnted https://www.openhab.org/addons/bindings/milight/
can you address this or should i put it on a different form
I would start a new topic to include mi light and new iBox not working. Or just new iBox not connecting to OH. That may help draw the attention of other iBox users. This topic âOpenhab image on raspberry pi 2 or 3â mentions nothing about iBox or mi light.
thank you for your help on openhab it works but the still does not resize to 32gb but the root is 27gb when you plug the card in mac it shows mb not gb i will post the mi light in the topic thatâs there to do with mi light i found one
