Issue of the topic:
I use openhab manually installed. I used it to send data ( Echocontrol LastvoiceCommand Channel ( items) ) outside to feed my HomeSeer install via mqtt.
I just tried The very same config with docker by curiosity. I am new to docker, but I can say that it is the only container/ image ( I have 4) that is slow to send data outside.
So data is not slow without Docker, but with docker it is slow. This is trange because i did set up the docker as host? And do not forward anything.
here is my docker run ââscriptââ docker run \ --name=openhab \ --net=host \ -h 127.0.0.1 \ --restart=always \ -v /etc/localtime:/etc/localtime:ro \ -v /etc/timezone:/etc/timezone:ro \ -v /opt/openhab/addons:/openhab/addons \ -v /opt/openhab/conf:/openhab/conf \ -v /opt/openhab/userdata:/openhab/userdata \ -e "EXTRA_JAVA_OPTS=-Duser.timezone=America/Toronto" \ -d \ -e USER_ID=Hidden \ -e GROUP_ID=Hidden \ openhab/openhab:latest
Maybe i missed something in the config?
Finally, I went back to my manual install , and all is going fast.
So I do not know if the data is slow to enter the docker container, Or if is is slow to send data outside via mqtt.
You need to elaborate more on âslowâ and âfastâ. There really isnât anything specific to Docker that would cause messages to be delayed. Especially when you run with --net=host there is literally nothing between the Docker container and the hardware (unlike a VM). All a container is is a label in the Linux kernel that causes the Linux kernel to keep the containerâs processes and access to stuff isolated. There should be no CPU or networking different between a process running in Docker and natively. So the problem has to be something about the configuration of OH inside the container that is making it slow.
Is the process pegging the CPU? Is OH receiving the message but slow to process it? Do you see errors in the logs?
Thanks for you reply. This was a dns issue. With the setup manually installed the dns was resolving a lot more⊠but sometime not to⊠and i didnât realize it.
The problem is that it is impossible to edit the dns file, there are simlinks everywhere ( i think this is when i went from ifup package to netplan.
Until I find the issue. i will run docker since i can specify directly the dns i want to use . âŠ
