When I start openHAB
[INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘influxdb.persist’
[DEBUG] [xDBPersistenceServiceActivator] - InfluxDB persistence bundle has been started.
[DEBUG] [i.i.InfluxDBPersistenceService] - influxdb persistence service activated
[ERROR] [i.i.InfluxDBPersistenceService] - influxdb:password
regular I can see this message:
[WARN ] [i.i.InfluxDBPersistenceService] - Configuration for influxdb not yet loaded or broken.
I monitored with tcpdump but don’t see any communication between InfluxDB and openHAB during startup.
Using curl I can save data into influxDB, and I can see the packages at tcpdump
I am having similar issues, influxdb seems to be working and if I run Openhab in debug mode i see
20:04:39.254 [TRACE] [i.i.InfluxDBPersistenceService:239 ] - storing Temperature_Roof_Central in influxdb value 24.4, Temperature_Roof_Central (Type=NumberItem, State=24.40)
Here is my influxdb.persist file
Strategies {
// If no strategy is specified for an item entry below, the default list will be used.
everyMinute : "0 * * * * ?"
default = everyUpdate }
Thanks for the reply, I have enabled DEBUG and TRACE logging and see the following when is start OH
2016-11-17 08:49:00.011 [TRACE] [i.i.InfluxDBPersistenceService] - Tried to get item from item class class org.openhab.core.library.items.NumberItem, state is 25.90_
2016-11-17 08:49:00.011 [TRACE] [i.i.InfluxDBPersistenceService] - found fractional part_
2016-11-17 08:49:00.011 [DEBUG] [i.i.InfluxDBPersistenceService] - got DecimalType value 25.9_
2016-11-17 08:49:00.011 [TRACE] [i.i.InfluxDBPersistenceService] - storing Temperature_Roof_Central in influxdb value 25.9, Temperature_Roof_Central (Type=NumberItem, State=25.90)_
You were right, it’s not OpenHab related. I set influxdb up on another server and pointed OH at it and that works. Going to try removing influxdb and doing a fresh install. Thanks
