- Platform information:
- Hardware: Raspberry Pi Zero W with 32G SD
- OS: openhasbian
I am new to the openHAB world. I have openhasbian running on my Pi 0 with no issues AFAIK.
I have about a dozen Insteon switches and a hub that I am trying to control through a USB PLM.
I have no idea how/which files to create to add these devices to openHAB (I did install the binding).
I tried using insteon terminal to test, and I’ve had no luck. The PLM can hear signals but I have had no luck sending commands. Here is my init.py items:
from console_commands import *
from keypad2487S import *
from thermostat2441TH import *
from modem2413U import *
from switch2477S import *
from dimmer2477D import *
from ledBulb2672 import *
from switch import *
from leaksensor import *
if you are using a hub, replace login and password below with your
hub login and password. Note: this is not the email address and password to
the insteon web site, but the login/password on the back of the hub
def connectToMyHub():
“”“connects to my insteon hub modem at pre-defined address”“”
connectToHub(“insteonhub”, 25105, 1000, “MyHubLogin”, “MyHubPassword”)
if you are using a legacy hub (pre-2014 hub)
def connectToMyLegacyHub():
connectToLegacyHub(“insteonhub”, 9761) # syntax is address, port (generally 9761)
def connectToMySerial():
“”“connects to my modem on pre-defined serial port”“”
connectToSerial(“/dev/insteon”)
connectToSerial(“/dev/ttyUSB0”)
uncomment correct line, depending on if you have a PLM modem or a hub (or a legacy hub)
to automatically connect on startup. You will also have to change the info in the corresponding connectToMy…() function
connectToMySerial()
#connectToMyHub()
#connectToMyLegacyHub()
Now define the devices you want to work with. For a list of
available devices, look at the source code in the “python” directory
Example device definitions
kp = Keypad2487S(“office_keypad”, “30.0d.9f”)
th = Thermostat2441TH(“kitchen_thermostat”, “32.f7.2c”)
modem = Modem2413U(“test_modem”, “23.9b.65”)
closetLight = Switch2477S(“closetLight”, “25.65.d6”)
dimmer = Dimmer2477D(“dining_room_dinner”, “20.ab.26”)
ledBulb = LEDBulb2672(“ledBulb”, “21.EB.DD”);
Modem = Modem2413U(“house_plm”, “48.f0.e7”)
Den = Switch(“denlight”, “36.0b.a9”)
HallLamps = Switch(“hall_lights”, “36.40.e9”)
LRLamp1 = Switch(“lrlamp1”, “36.42.19”)
LRLamp2 = Switch(“lrlamp2”, “2d.1d.81”)
Outdoor = Switch(“outdoor”, “37.e8.c5”)
Upstairs = Switch(“upstairs”, “35.1f.d6”)
PorchLight = LEDBulb2672(“porchlight”, “47.3f.6b”)
BathroomLeak = LeakSensor(“leaksensor”, “40.30.4e”)
Any help would be greatly appreciated!
Thanks.
Mike
