Hello guys,
I’ve got a problem in my enviroment, I configured everything to work with deconz (Conbee) and Alexa. And everything worked fine. But in the last days, the Items are not reachable via Alexa, neither per voice control nor via app.
When I check the logs, there is a log entry spammed:
2021-12-20 19:38:47.097 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
Hi Marcel.
I don’t know what version of OH you are on?
I was having similar problem and I found this
It did help me with some of the problems I was having, however are you aware that the OpenHAB Alexa Skill has had a massive update last week and you may want to check the updated documentation and also the syntax on the Alexa Meta tags.
Hope this points you in the right direction
