I am trying to install openHAB next to a running nextcloudpi system on my raspi4 (I hope that is not the cause of my issue).
Regardless, I have started to do the steps according to the “Manual Setup” in the docs. The first difference occurred after the Zulu installation. I could not choose an alternative when I sent the command:
sudo update-alternatives --config java
So, it seemed that only Zulu and no alternative had been installed up to that point. Meanwhile, I have installed some other versions and the open-jdk as well. The output now is:
0 /usr/lib/jvm/java-11-openjdk-arm64/bin/java 1111 auto mode
1 /opt/jdk/zulu11.43.100-ca-jdk11.0.9.1-linux_aarch32hf/bin/java 1 manual mode
* 2 /opt/jdk/zulu11.45.27-ca-jdk11.0.10-linux_aarch32hf 1 manual mode
3 /usr/lib/jvm/java-11-openjdk-arm64/bin/java 1111 manual mode
The next difference occurs when i start the installtion of openHAB:
sudo apt-get install openhab
openHAB cannot detect Java:
[openHAB] WARNING: We were unable to detect Java 11 on your system. This is needed before openHAB can be started.
[openHAB] Please install the current version of Java 11 or check the openHAB documentation for details.
Processing triggers for systemd (241-7~deb10u6) ...
Logically I have errors when starting openHAB service with
sudo systemctl start openhab.service
The status says:
pi@nextcloudpi:~ $ sudo systemctl status openhab.service
● openhab.service - openHAB - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab.service; disabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sun 2021-02-28 09:21:32 GMT; 4s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 1819 ExecStart=/usr/share/openhab/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=exited, status=1/FAILURE)
Main PID: 1819 (code=exited, status=1/FAILURE)
And the logfile:
sudo journalctl -u openhab.service -b
-- Logs begin at Sun 2021-02-28 08:29:11 GMT, end at Sun 2021-02-28 09:22:33 GMT. --
Feb 28 09:21:17 nextcloudpi systemd[1]: Started openHAB - empowering the smart home.
Feb 28 09:21:17 nextcloudpi karaf[1765]: java command not found
Feb 28 09:21:17 nextcloudpi systemd[1]: openhab.service: Main process exited, code=exited, status=1/FAILURE
Feb 28 09:21:17 nextcloudpi systemd[1]: openhab.service: Failed with result 'exit-code'.
Feb 28 09:21:22 nextcloudpi systemd[1]: openhab.service: Service RestartSec=5s expired, scheduling restart.
Feb 28 09:21:22 nextcloudpi systemd[1]: openhab.service: Scheduled restart job, restart counter is at 1.
Feb 28 09:21:22 nextcloudpi systemd[1]: Stopped openHAB - empowering the smart home.
Feb 28 09:21:22 nextcloudpi systemd[1]: Started openHAB - empowering the smart home.
Feb 28 09:21:22 nextcloudpi karaf[1785]: java command not found
Furthermore, no java-version appears when select Zulu as active configuration:
pi@nextcloudpi:~ $ java -version
-bash: java: command not found
otherwise when activating openjdk the output is:
openjdk version "11.0.9.1" 2020-11-04
OpenJDK Runtime Environment (build 11.0.9.1+1-post-Debian-1deb10u2)
OpenJDK 64-Bit Server VM (build 11.0.9.1+1-post-Debian-1deb10u2, mixed mode)
Is there a way to fix this?
