Openhab.log error byte stream as response
openHABian 3.4.3 on rPi4 with 4GB
Yes, dated version, but I’ve seen this on v4 as well.
What am I seeing:
2025-11-01 15:28:02.094 [ERROR] [ab.core.ui.icon.internal.IconServlet] - Failed sending the icon byte stream as a response: null
2025-11-01 15:28:02.095 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /icon/solarpanels
java.lang.IllegalStateException: ABORTED
I looked everywhere, even put the icon in the path being complained about; still pops up… BUT…
I found something here:
# [2025-11-01 16:50] openhabian@openhabian /var/lib/openhab $
sudo grep -r -i solarpanels
jsondb/backup/1761484260997--org.openhab.core.items.Item.json:      "category": "solarpanels",
jsondb/backup/1761484112047--org.openhab.core.items.Item.json:      "category": "solarpanels",
jsondb/backup/1761484237857--org.openhab.core.items.Item.json:      "category": "solarpanels",
jsondb/backup/1761484208110--org.openhab.core.items.Item.json:      "category": "solarpanels",
jsondb/backup/1761484179379--org.openhab.core.items.Item.json:      "category": "solarpanels",
jsondb/org.openhab.core.items.Item.json:      "category": "solarpanels",
grep: backups/openhab-backup-22_11_26-12_58_04.zip: binary file matches
grep: backups/openhab-backup-23_02_18-10_05_07.zip: binary file matches
grep: persistence/mapdb/storage.mapdb.p: binary file matches
… but what do I do with this info?!
What about this:
Thanks; nice find, but none of it applies; did not open the sitemap on the iPhone; did not change an icon in the sitemap. this error pops up randomly… and have seemingly enough memory free.
top - 20:39:05 up 479 days, 21:31,  5 users,  load average: 0.29, 0.27, 0.26
Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1.6 us,  0.5 sy,  0.0 ni, 97.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   3844.2 total,    271.6 free,   2058.1 used,   1514.5 buff/cache
MiB Swap:   3072.0 total,   2948.0 free,    124.0 used.   1723.1 avail Mem
But, it might not be worth spending too may brain cycles on this; as I:
a) can live with it
b) may eventually kick myself to go to v5?! :slight_smile:
You may have enough free and if so you could make the change suggested and allocate it to openHab program which may not have enough memory. It is worth a try. The iPhone sitemap stuff is irrelevant but the symptom is the same.
