Yes it works !
Thank you very much for your support.
I hope that this solution will help many other users!
Yes it works !
Hi, I’ve got same issue and discovered that since January 2 threre is no update of the long. Neither in the frontail nor in the log file.
I tried to follow all above and update socket.io from 2.3.0 to 2.4.1 but it stayed 2.3.0.
├─┬ socket.io@2.3.0
│ ├── socket.io-adapter@1.1.2
│ ├─┬ socket.io-client@2.3.0
│ │ ├─┬ socket.io-parser@3.3.2
│ └─┬ socket.io-parser@3.4.1
Any idea, why the update fails? And if this might be the rootcause for not running frontail?
UPDATE: not running log at frontail was obviously not an issue of socket.io version. After downgrade to 2.3.0 (as indicated in other threads) and re-install latest stable version of openhab (not only upgrade to the latest version), it logs again.
