I think I messed something up. I was following this tutorial:
and everything was working fine until I got to the instruction where it says to change
<logger name="org.openhab" level="INFO"/>
to
<logger name="org.openhab" level="DEBUG"/>
and now it doesn’t seem to be logging anything. I tried changing it back but it still isn’t doing anything. When I try to tail the log file I just get the same couple of items and nothing after that. This is what the tail looks like:
pi@raspberrypi:~ tail -f /var/log/openhab/openhab.log
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777) ~[na:1.8.0_91]
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141) ~[na:1.8.0_91]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213) ~[na:1.8.0_91]
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643) ~[na:1.8.0_91]
at com.sun.org.apache.xalan.internal.xsltc.compiler.Parser.parse(Parser.java:431) ~[na:1.8.0_91]
at com.sun.org.apache.xalan.internal.xsltc.compiler.Parser.parse(Parser.java:506) ~[na:1.8.0_91]
at com.sun.org.apache.xalan.internal.xsltc.compiler.XSLTC.compile(XSLTC.java:466) ~[na:1.8.0_91]
at com.sun.org.apache.xalan.internal.xsltc.compiler.XSLTC.compile(XSLTC.java:568) ~[na:1.8.0_91]
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTemplates(TransformerFactoryImpl.java:977) ~[na:1.8.0_91]
... 5 common frames omitted
What did I do wrong?
