I’ve successfully installed openHAB on a raspberry.
It’s working with Loxone through Google Home.
But I’m only able to control the lights and moods.
It took a while to get it working. The clue was to set the “Item Linking” to “Simple Mode”.
I read that there’s a way to not use “Simple Mode” and configure manually.
But… I couldn’t get it working.
My question is, will I be able to control more Loxone functions if I disable the “Simple Mode” and configure it manually? (Like room temperature, … )
And if Yes, how can I establish this?
Regards,
Peter
