yes it is the AI Agent:
if I use the docke mcp gateway this works fine, but only with public mcp servers what are in the docker catalog.
i have still some issues with the docker container (after i read all the comments here).
First of all: there is no container log to get a error messageâŠwould be easier to have as least âsomethingâ.
So i have no clue, if the container is able to reach the openhab-container (and ping&curl ist not installable inside the container to verify it)
But is there a usable endpoint if the openhab-mcp-container is running (My container got own static IP) something like
GET http://IPofContainer:8080/mcp or else just to get some kind of a lifesign?
fyi: I used the GitHub - tdeckers/openhab-mcp: An MCP server for OpenHAB repo.
I recommend to use MCP inspector: MCP Inspector - Model Context Protocol
It is an easy way to connect to your Server locally so that is good for quick debugging. If the connection to your server works you can also invoke tool calls. This should produce errors in the server log if your container cannot reach OH.
Also you may want to set the log level to DEBUG in openhab_mcp_server.py in line 18.
Hi team, i wondered if anyone had looked into the work being done over at Agntcy, seems like it could be a great way to support this evolving field and both A2A and MCP are supported.
I think I found your issue. It seems that FASTMCP_HOST is no longer working in the latest mcp versions. I will update the code soon to get this fixed.
Oh thanks!
(sorry, that i didnât answer but i had not enough time, to debug this project locally)
It would be cool, if debug-logs would be available, if i start the container with a ENV-variable (DEBUG=true for example), because my container runs on my NAS and next time (if needed ^^) i want to give better input.
Yes there are a few things that need to be cleaned up including some no longer needed files and the README. I think I will also add some variables to specify the interface and port the server listens on (only required if the defaults donât work for you) and also the log level. I will probably also lock the versions of the requirements so that the behaviour should be more stable in the future.
I did some fundamental restructurings in my repo, added somenew env variables and also updated the README. I hope that it should be much easier to set up a new installation now.
I just realized that tdeckers also had updates in his repo (the one I forked from) but I think my changes might have diverged too farâŠ
Works on first try today. Tried it yesterday unsuccessfully. Maybe your new commited changes made it run.
Have it working locally on macOS, python 3.13.3 in combination with LM Studio and a locally running LLM (openai/gpt-oss-20b).
Integrated in to the LM Studio Chat via
"mcpServers": {
"openhab": {
"url": "http://localhost:8000/mcp"
Looks and feels awesome, my first MCP experience. Now I need to find out, what I can do with it. ![]()
Example:
Question: âWieviele Items gibt es, die sich auf Luftfeuchtigkeit beziehen?â
Answer:
openai/gpt-oss-20b
Thought for a brief moment
list_items
mcp/openhab
Es gibt 11 Items, die sich auf Luftfeuchtigkeit beziehen.
Question: âNennen mir die 11 Items.â
Answer:
openai/gpt-oss-20b
list_items
mcp/openhab
Hier die Namen der 11 LuftfeuchtigkeitsâItems:
pDGBueroKlimaSensor_Humidity
pDGGaestezimmerKlima_Humidity
pEGVorgartenSensor_Humidity
pEGWCKlima_Humidity
pEGWZWandThermostat_Humidity
pOGBadHZGruppe_Humidity
pOGKiZ1Heizung_ActualHumidity
pOGKiZ2KlimaSensor_Humidity
pOGSZHZGruppe_Humidity
pDGGaestezimmerKlima_Pressure (dieses ist eigentlich Druck, aber im Listing erscheint mit HumidityâTag â falls nötig ausklammern)
pEGWCKlima_Pressure (Ă€hnlich wie 10, ggf. ausklammern)
Falls du nur reine Luftfeuchtigkeitswerte ohne DruckâItems möchtest, wĂ€ren die 9 ersten eindeutig.
Is there any existing android ai which can connect to an mcp server?
Can confirm this working now also on Codex cli. Thanks for the effort!
to configure codex cli, edit your .toml file
/home/[YOURLOGGEDONUSER]/.codex/config.toml
[mcp_servers.openhab]
url = âhttp://[YOURMCPSERVER]:8080/mcpâ
Iâve been playing around with Claude and openHAB MCP server. Claude says it has some issues, so I asked it to generate a report.
Anyone else has issues with send_command, update_item_state, create_rule or create_script?
Date: January 10, 2026
Reporter: Claude (AI Assistant)
Context: Implementing MiLight automation with PIR sensors, timers, and dynamic color temperature based on sun elevation
During an automation implementation session, several issues were encountered with the openHAB MCP tools. The most critical issues prevent rule creation entirely, while others cause confusing error messages despite successful command execution.
send_command Tool Returns Validation Error Despite SuccessThe send_command tool returns a Pydantic validation error even when the command is successfully executed on the openHAB server.
Tool call: send_command
Parameters:
- item_name: "Milight_ID0x2_G1_Level"
- command: "50"
Success response confirming command was sent.
Error executing tool send_command: 1 validation error for send_commandOutput
result
Input should be a valid dictionary [type=dict_type, input_value=True, input_type=bool]
For further information visit https://errors.pydantic.dev/2.12/v/dict_type
Immediately after the error, calling get_item_state confirms the command was executed:
get_item_state("Milight_ID0x2_G1_Level") -> "50"
The openHAB REST API likely returns true (boolean) for successful POST requests to /rest/items/{itemname}. The Pydantic model for send_commandOutput expects a dictionary but receives a boolean.
# Current (problematic):
class send_commandOutput(BaseModel):
result: dict
# Suggested fix:
result: Union[dict, bool, None]
Or handle the boolean response explicitly in the tool implementation before returning.
update_item_state Tool Returns Same Validation ErrorSame issue as send_command - the tool works but returns a validation error.
Tool call: update_item_state
Parameters:
- state: "50"
Error executing tool update_item_state: 1 validation error for update_item_stateOutput
result
Same as Issue 1 - boolean response not handled by Pydantic model.
create_rule Tool Fails CompletelyThe create_rule tool fails with an AttributeError, preventing any rule creation through the MCP interface.
Tool call: create_rule
Parameters:
- rule: {
"uid": "MiLight_Test1",
"name": "MiLight Test Rule",
"tags": [],
"actions": [],
"triggers": [],
"conditions": [],
"configuration": {},
"configDescriptions": []
Rule created successfully.
Error executing tool create_rule: 'RuleCreate' object has no attribute 'raise_for_errors'
The error suggests that somewhere in the tool implementation, thereâs a call to .raise_for_errors() on a RuleCreate Pydantic model object. This method doesnât exist on Pydantic models.
Look for code similar to:
rule = RuleCreate(**rule_data)
rule.raise_for_errors() # This line is wrong
Should probably be:
response = api_client.post("/rest/rules", json=rule.dict())
response.raise_for_status() # This is correct for httpx/requests
create_script Tool Has Incorrect Parameter HandlingThe create_script tool reports a missing required argument even when all parameters are provided.
Tool call: create_script
Parameters:
- script_id: "milight_calc_ctemp"
- script_type: "application/javascript;version=ECMAScript-2021"
- content: "// script content here..."
Error executing tool create_script: OpenHABClient.create_script() missing 1 required positional argument: 'content'
Despite content being provided in the parameters, the method reports it as missing. This suggests:
Check that the MCP tool parameter names match the OpenHABClient.create_script() method signature exactly.
| Tool | Issue | Severity | Workaround |
send_command |
Returns validation error despite success | Medium | Ignore error, verify with get_item_state |
update_item_state |
create_rule |
Fails with AttributeError | Critical | Use file-based configuration instead |
create_script |
Missing argument error | Critical | Use file-based configuration instead |
Due to these issues, rule and script creation had to be done via file-based configuration rather than the MCP interface. This required:
The send_command and update_item_state issues are workable (commands do execute), but the error messages are confusing and could lead users to believe commands failed when they actually succeeded.
create_rule and create_script tools to enable programmatic rule managementsend_command and update_item_state to properly handle boolean responsesReport generated during MiLight automation implementation session
Two questions: which MCP server did you use? The tdecker repo or mine? Which openHAB version are you using? Iâve not yet tested this on OH5 so there might be issues.
Iâm using your repo. No docker but installed in itâs own Python virtual env.
Ok good. Which OH version? Can you execute the tests? There are a few rule test cases that worked fine for me (on OH 4)
openHAB 5.0.2
I was using the repo from your first post. Now Iâve changed to your repo and run the 2 tests:
(venv) [stefan@spin openhab-mcp]$ OPENHAB_URL=http://openhab.xxx.net:8080 OPENHAB_API_TOKEN=oh.ClaudeDesktop.WxxxxBUA python3 tests/test_items.py
E......E
ERROR: test_create_item_with_all_fields (__main__.TestOpenHABItems.test_create_item_with_all_fields)
Test creating an item with all possible fields and verify they are set correctly.
Traceback (most recent call last):
File "/home/stefan/git/openhab-mcp/tests/test_items.py", line 369, in test_create_item_with_all_fields
self.assertIn("Equipment_Lighting", created_item["semanticTags"][0]["uid"])
IndexError: list index out of range
ERROR: test_update_item_with_none_or_empty_values (__main__.TestOpenHABItems.test_update_item_with_none_or_empty_values)
Test updating an item with None or empty list values to remove properties
File "/home/stefan/git/openhab-mcp/tests/test_items.py", line 444, in test_update_item_with_none_or_empty_values
Ran 9 tests in 58.031s
FAILED (errors=2)
(venv) [stefan@spin openhab-mcp]$ OPENHAB_URL=http://openhab.xxx.net:8080 OPENHAB_API_TOKEN=oh.ClaudeDesktop.WxxxxECBUA python3 tests/test_rules.py
Ran 6 tests in 0.426s
OK
Whoops sorry I got a bit confused⊠Iâm also running 5.0.2, not 4.xâŠ
So I just tried to create a rule on my end and it seems to be broken for me as well⊠I will have to investigate whatâs wrong here but this does not seem to be a specific problem with your setup.
Ok, I cannot reproduce all of your errors here but I found some other problems that might at least in parts be related to your observations for item updates/commands.
Can you please try to run the latest and greatest code on the main branch? All test cases are green here. In the meantime I switched to OH 5.1.1 but I donât think there there were any major API changes that might be breaking hereâŠ
send_command and update_item_state are working correct now.
(venv) [stefan@spin openhab-mcp]$ OPENHAB_URL=http://openhab.xxx.net:8080 OPENHAB_API_TOKEN=oh.ClaudeDesktop.WNa7OnBexxxanJ3XfU4ECBUA pytest tests/
============================================================================================================= test session starts ==============================================================================================================
platform linux -- Python 3.13.11, pytest-9.0.2, pluggy-1.6.0
rootdir: /home/stefan/git/openhab-mcp
configfile: pyproject.toml
plugins: anyio-4.12.0
collected 16 items
tests/test_items.py .F......F [ 56%]
tests/test_rules.py ....... [100%]
=================================================================================================================== FAILURES ===================================================================================================================
______________________________________________________________________________________________ TestOpenHABItems.test_create_item_with_all_fields _______________________________________________________________________________________________
self = <tests.test_items.TestOpenHABItems testMethod=test_create_item_with_all_fields>
def test_create_item_with_all_fields(self):
"""Test creating an item with all possible fields and verify they are set correctly."""
# Create a group item first to use in group_names
group_name = f"{self.test_prefix}TestGroup"
group_item = self.client.create_item(ItemCreate(
name=group_name,
type="Group",
label="Test Group",
groupType="Dimmer",
function={"name": "AVG"}
# Create an item with all possible fields
item_name = f"{self.test_prefix}FullItem"
item = ItemCreate(
name=item_name,
type="Dimmer",
label="Test Full Dimmer Item",
category="Light",
groupNames=[group_name],
semanticTags=["Equipment_Lighting"],
nonSemanticTags=["TestTag", "Dimmable"],
metadata={
"commandDescription": ItemMetadata(value=" ", config={
"options": "ON=Switch ON, OFF=Switch OFF, INCREASE=Increase, DECREASE=Decrease"
"stateDescription": ItemMetadata(value=" ", config={
"minimum": 0,
"maximum": 100,
"step": 5,
"pattern": "%d%%",
"readOnly": False,
"options": "0=Off, 100=Full"
"unit": ItemMetadata(value="%")
# Create the item
created_item = self.client.create_item(item)
try:
# Verify the item was created with all fields
self.assertEqual(created_item["name"], item_name)
self.assertEqual(created_item["type"], "Dimmer")
self.assertEqual(created_item["label"], "Test Full Dimmer Item")
self.assertEqual(created_item["category"], "Light")
# Verify group membership
self.assertIn(group_name, created_item["groupNames"])
# Get the group to verify its properties
group = self.client.get_item(group_name)
self.assertEqual(group["groupType"], "Dimmer")
self.assertEqual(group["function"]["name"], "AVG")
# Verify tags
self.assertIn("TestTag", created_item["nonSemanticTags"])
self.assertIn("Dimmable", created_item["nonSemanticTags"])
E IndexError: list index out of range
tests/test_items.py:369: IndexError
_________________________________________________________________________________________ TestOpenHABItems.test_update_item_with_none_or_empty_values __________________________________________________________________________________________
self = <tests.test_items.TestOpenHABItems testMethod=test_update_item_with_none_or_empty_values>
def test_update_item_with_none_or_empty_values(self):
"""Test updating an item with None or empty list values to remove properties"""
# First create an item with various properties
item_name = "TestItem_UpdateWithNone"
group_name = "TestItem_TestGroupForUpdate"
# Create a group first
name=group_name,
type="Group",
label="Test Group for Update",
groupType="Dimmer",
# Create initial item with all properties
item = ItemCreate(
name=item_name,
type="Dimmer",
label="Test Item for Update",
category="Light",
metadata={
"pattern": "%d%%",
"readOnly": False,
# Create the item
try:
self.assertEqual(created_item["label"], "Test Item for Update")
tests/test_items.py:445: IndexError
=========================================================================================================== short test summary info ============================================================================================================
FAILED tests/test_items.py::TestOpenHABItems::test_create_item_with_all_fields - IndexError: list index out of range
FAILED tests/test_items.py::TestOpenHABItems::test_update_item_with_none_or_empty_values - IndexError: list index out of range
======================================================================================================== 2 failed, 14 passed in 58.09s =========================================================================================================
Some tests are still failing.
