hi Kai, what if the original maintainer seems to have left the building?
Fix it yourself or find someone else interested in having it fixed .
Please note that you can from now on find direct links to the latest milestone on https://www.openhab.org/download/
as well as some explanation between the different versions for novice users.
Feel free to provide feedback!
Excellent! Why was this only done now by December 2018? Would have liked to have these clear options for years. Great work!
You need to sign up to the “Announcement” section and you will never miss such information, and of course, you need to read. “Watching first post” is very handy if you don’t like to be notified on every single message.
I agree but the new links on the download page are MUCH EASIER and also suitable for every newcomer who has not read this forum for years. I think OH suffered a lot in the past form all these complicated scattered information which made it unnecessary hard for every beginner to join in. Normally you would expect this information on the download page of the main website (where it finally arrived now) and I really appreciate this!
From what I remember: The download section already had the direct links for manual deployment of the 2.3.0 Stable Release (since the website was revamped during the summer of 2018)
The recent change was about the addition of the Milestone builds/releases for testing purposes (the Milestones are not very appropriate for newcomers )
sorry for the noob question
how can we know in which current milestone is currently openhab?
how to know what is the milestone of the openHAB 2.4.0 Build #1451?
Did M8 go out without an announcement?
I havent seen it announced.
You’re right, I missed to mention it here. Here are the changes that are included in M8:
Eclipse SmartHome:
- [homematic] Use system channel for PRESS datapoint (#6587) (detail / githubweb)
- Ability for scale transformation to work with QuantityType (#6606) (detail / githubweb)
- Fix Eclipse JUnit Plug-in Test configurations (#6609) (detail / githubweb)
- Added OAuth2 bundle to feature list. (#6607) (detail / githubweb)
- [MQTT] fix number formattting (#6613) (detail / githubweb)
- [MQTT] fix connection handling for command-only channels (#6615) (detail / githubweb)
- refactor isFloat to isDecimal (#6616) (detail / githubweb)
- Paper UI: Fix group item creation for base type None (#6623) (detail / githubweb)
- Paper UI: move disabled button to thing list (#6622) (detail / githubweb)
- [MQTT] removed full network scan mqtt discovery service (#6618) (detail / githubweb)
- RuleEngine: ItemCommandAction: Use input for commands to allow module (detail / githubweb)
- [MQTT] added brokerid to configuration (#6624) (detail / githubweb)
- Implements new reference syntax: list[index], map[“key”], bean.field (detail / githubweb)
- updated contributor list (#6627) (detail / githubweb)
- upgraded to JUPnP 2.5.0 (#6625) (detail / githubweb)
- upgraded to JmDNS 3.5.5 (#6628) (detail / githubweb)
- [Hue] Fixed brightness of 1 shown as off (#6629) (detail / githubweb)
- reduced some logging to debug level (#6634) (detail / githubweb)
- Setting stop timeout to 0 in order to avoid blocking the component (detail / githubweb)
- Added STATE_CONTACT support for all HMIP-SWDO devices (#6633) (detail / githubweb)
- correct swagger response type definition (#6638) (detail / githubweb)
- Fix storing empty refresh token on refreshToken call. (#6637) (detail / githubweb)
- Corrected documentation for channelLinked method (#6642) (detail / githubweb)
- Add missing Automatic-Module-Name manifest entries (#6650) (detail / githubweb)
- MQTT: Fix disconnect. Fix generic percentage channel. (#6648) (detail / githubweb)
- Added documentation about bridge configuration (#6644) (detail / githubweb)
- [io.net] Added test for null subject-alternative-names and fixed the NPE (detail / githubweb)
- [meteoblue] Remove test bundle because it has no tests and shows errors (detail / githubweb)
openHAB Core:
- Update dashboard / place 1st the Standard package (#442) (detail / githubweb)
- added oauth2 client (#440) (detail / githubweb)
- Bump ZigBee libraries to 1.1.6 (#446) (detail / githubweb)
- updating nrjavaserial (#447) (detail / githubweb)
openHAB2 Add-ons:
- Hue emulation: Improve class documentation (#4310) (detail / githubweb)
- Hue emulation: Extend AbstractHueState (#4313) (detail / githubweb)
- Hue emulation: Extend HueDevice response (#4312) (detail / githubweb)
- Hue emulation: Fix the user created message (#4311) (detail / githubweb)
- [KNX] Update
localSourceAddr
label & description (#4308) (detail / githubweb) - Fix Eclipse JUnit Plug-in Test configurations (#4299) (detail / githubweb)
- Re-implementation PLCLogo binding for openHAB2. (#2286) (detail / githubweb)
- Fix Nullannotations in Hue emulation which break the Eclipse build (detail / githubweb)
- [solaredge] improved handling of configuration / fixed handling of (detail / githubweb)
- [nibeuplink] improved handling of configuration / fixed handling of (detail / githubweb)
- [miio] Initial Contribution Mi IO Binding (#2548) (detail / githubweb)
- [KNX] Extend *-control channels (#4258) (detail / githubweb)
- [tesla] Allow vehicle to sleep to fix vampire drain (#4218) (detail / githubweb)
- HueEmulation: Fixes and test bundle (#4324) (detail / githubweb)
- [chromecast] General Improvements (#4325) (detail / githubweb)
- [icloud] make certificate provider work in IDE as well (#4328) (detail / githubweb)
- [nibe] Fixed issue related to linked channels (#4326) (detail / githubweb)
- [amazonEchoControl] [Improvement] feature update: mobile app based (detail / githubweb)
- [miio] update readme (#4330) (detail / githubweb)
- [icloud] Improved the lifecycle (#4329) (detail / githubweb)
- [network] Use refreshInterval in thing type definitions (#4331) (detail / githubweb)
- Network: Null type annotations. Fix property xml<–>code mismatch. (detail / githubweb)
- [network] Fix SAT findings and some code improvements (#4334) (detail / githubweb)
- Add missing Automatic-Module-Name manifest entries (#4336) (detail / githubweb)
- [smartmeter] Fix test build path (#4337) (detail / githubweb)
- Yamaha zones: Add representation-property (#4314) (detail / githubweb)
- Hue emulation: User creation fix, storage service fix, turn white fix, (detail / githubweb)
- Hue emulation: Don’t use getParameter on a HttpServletRequest (#4343) (detail / githubweb)
- Milight: Use any free port instead of fixed port on client-side for (detail / githubweb)
- New OH2 Binding for KM200 devices (#1877) (detail / githubweb)
- [modbus] Dimmer example (#4196) (detail / githubweb)
- [UniFi] Initial contribution (#3387) (detail / githubweb)
- [HD PowerView] Fix quoted ID issue (#3470) (detail / githubweb)
- Modbus performance and logging improvements (#4304) (detail / githubweb)
- [modbus] Support for 64 bit integers on read & write (#4276) (detail / githubweb)
Z-Wave Binding:
- Revert “use SecureRandom to generate S0 security key (#1032)” (#1079) (detail / githubweb)
- Improve handling of unknown device classes (#1077) (detail / githubweb)
- Database update (#1081) (detail / githubweb)
- Revert ‘Support discovery of USB dongles’ (#902) (#1082) (detail / githubweb)
- Database update (#1084) (detail / githubweb)
- Create x.txt (detail / githubweb)
- Delete x.txt (detail / githubweb)
- Create .gitignore (detail / githubweb)
- Database update (#1086) (detail / githubweb)
Zigbee Binding:
- Channel converter for the IAS tamper attribute (#311) (detail / githubweb)
- Fix color temperature from/to percent conversion in color temperature (detail / githubweb)
- CC2531EMK dongle doesn’t pass the MatchDescriptor (#270) (detail / githubweb)
- Update binding to latest ZSmart Systems library (#332) (detail / githubweb)
- Improved handling of OTA initialisation (#319) (detail / githubweb)
- Handle OnOff command in level converter same as switch converter (#318) (detail / githubweb)
openHAB Distro:
- Added meteoblue binding to features (#819) (detail / githubweb)
- [amazonechocontrol] Update update.lst (#817) (detail / githubweb)
- Bump Z-Smart Systems library to 1.1.6 (#821) (detail / githubweb)
- Add Jenkins Release Pipeline script (#822) (detail / githubweb)
- Fix wrong type of quotation marks in target config file (#824) (detail / githubweb)
- Milight, hue emulation breaking changes (#825) (detail / githubweb)
Thanks a lot.
I will try it right away!
I love the new Milestone release approach!
Done!
Awesome - No changes needed.
Using new km200, new amazonecontrol.
No issues
@David_Graeff my values of my MQTT items suddenly seem to be divided by 10 is this part of some api change? Or do you need more information?
Also my time-of-day rule has some regression problems (since a few weeks), it reports day but it is seriously dark out here, there also moments where it worked, but it used to be more accurate. Did you, @rlkoshak already test and notice this as wel
My fault. The different types of channels were not tested and I made a commit where I removed custom parsing code and replaced it with the TypeParser class (to allow INCREASE on a number channel for example). The number and color channels broke.
There is a hot fix already merged by Kai and a proper fix commit with tests on its way.
After upgrading to 2.4 M8 I receive a lot of Errors in Paper UI: 503 Jersey is not ready yet!
I tried clearing browser cache, different browser and openhab restart.
Never had those Problems with 2.3
I have also upgraded but how can you know that you are currently in m8 ?
my build number is 2.4.0-SNAPSHOT Build #1458.
i do not see a place to validate what is my current milestone
i can not find any indications on the build number in https://ci.openhab.org/job/openhab2-release/64/
I have not noticed anything. Look at the Astro binding. You should see around midnight in openhab.log some statements from the Astro binding saying it is calculating the times for the new day. If you don’t see those it means that your Astro Items are not updated and the Astro events are not occurring.
