I am not strong in Linux, and I know there are several ways of doing things, but I want to do it the “OpenHAB way.”
I followed this guide, and every time I reboot my RPi, I need to log in and manually start OpenHAB. How do I set OpenHAB to autostart? I spoke with the author of the guide and he is under the impression that simply following his steps should automatically set it to start.
I read through that and frankly a lot of the lines confuse.me. I am running OpenHAB on Raspbian Jesse and what I have done so far with the above walkthrough seems to have already created a service. I just need to know the recommended way to set it to auto start.
pi@OpenHAB ~ $ sudo service openhab status
● openhab.service - Starts and stops the openHAB Home Automation Bus
Loaded: loaded (/usr/lib/systemd/system/openhab.service; disabled)
Active: active (running) since Wed 2015-10-21 20:38:11 CDT; 1 day 13h ago
Docs: http://www.openhab.org
Process: 1702 ExecStartPre=/usr/share/openhab/bin/setpermissions.sh (code=exited, status=0/SUCCESS)
Main PID: 1898 (openhab.sh)
CGroup: /system.slice/openhab.service
├─1898 /bin/sh /usr/share/openhab/bin/openhab.sh -o
└─1919 /usr/bin/java -Dlogback.configurationFile=/etc/openhab/logback.xml -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=8080 -Dopenhab.configfile=/etc/openhab/configurations/openhab.cfg -Dop...
Oct 23 10:14:53 OpenHAB openhab.sh[1898]: 2015-10-23 10:14:53.616 [INFO ] [runtime.busevents ] - Nest_last_connection state updated to 2015-10-23T09:22:38
Oct 23 10:14:53 OpenHAB openhab.sh[1898]: 2015-10-23 10:14:53.621 [INFO ] [runtime.busevents ] - NestHumidity state updated to 45
Oct 23 10:14:53 OpenHAB openhab.sh[1898]: 2015-10-23 10:14:53.625 [INFO ] [runtime.busevents ] - Nest_target_temp_f state updated to 74
Oct 23 10:14:53 OpenHAB openhab.sh[1898]: 2015-10-23 10:14:53.629 [INFO ] [runtime.busevents ] - Nest_hvac_state state updated to off
Oct 23 10:15:54 OpenHAB openhab.sh[1898]: 2015-10-23 10:15:54.545 [INFO ] [runtime.busevents ] - Nest_temperature_scale state updated to F
Oct 23 10:15:54 OpenHAB openhab.sh[1898]: 2015-10-23 10:15:54.548 [INFO ] [runtime.busevents ] - NestAmbTemp state updated to 74
Oct 23 10:15:54 OpenHAB openhab.sh[1898]: 2015-10-23 10:15:54.552 [INFO ] [runtime.busevents ] - Nest_last_connection state updated to 2015-10-23T09:22:38
Oct 23 10:15:54 OpenHAB openhab.sh[1898]: 2015-10-23 10:15:54.556 [INFO ] [runtime.busevents ] - NestHumidity state updated to 45
Oct 23 10:15:54 OpenHAB openhab.sh[1898]: 2015-10-23 10:15:54.558 [INFO ] [runtime.busevents ] - Nest_target_temp_f state updated to 74
Oct 23 10:15:54 OpenHAB openhab.sh[1898]: 2015-10-23 10:15:54.560 [INFO ] [runtime.busevents ] - Nest_hvac_state state updated to off
Thank you @watou and @gonium. This was indeed my issue. OpenHAB is now starting as expected. I have also notified the author of the oversight in hopes of sparing others the frustration. I will now review the official guide and make sure nothing else is missed.
