Hello!
I’m using OpenHAB 2 for a pretty long time, and never had any problems with it after updating. But recently (6 days ago), I’ve tried to update my installation with 09.05.2018 nightly and wasn’t able to start OpenHAB afterwards. I was following this to the letter (as I did many times before), but after trying to run OpenHAB (both, as a service - the way I usually run it, and by running start.bat) all I get is “Launching the OpenHAB runtime…” message. I can see java.exe process is not taking any CPU time, so, I guess nothing is happening. After reverting back to a backup, everything works fine (I was running 1227 nightly). Today, I’ve tried updating once again, with today’s nightly (15.05.2018), but with the same result (only “Launching the OpenHAB runtime…” message). Anyone had similar problem? The update I’ve done today had the same starting point (nightly 1227). Any help would be greatly appreciated.
Edit: I’ve found this inside OpenHAB.log, and I guess it has something to do with the problem I’m having, but I really don’t have a slightest idea how to solve it
Error installing boot feature repository mvn:org.apache.karaf.features/standard/4.1.3/xml/features
java.io.IOException: Error resolving artifact org.apache.karaf.features:standard:xml:features:4.1.3: [Could not find artifact org.apache.karaf.features:standard:xml:features:4.1.3 in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.3/)] : mvn:org.apache.karaf.features/standard/4.1.3/xml/features
Best regards,
Davor
