OpenHAB not working after JRE Reinstall
I’ve been using 1.7 for a while now and things have been running pretty smoothly. Then something went wacky with Windows 10 and I had go restore an old image of it. I figured it would be a good time to jump to 1.8, but it has not been pleasant.
When I try to run OpenHAB now, I am getting all sorts of errors. I went back to 1.7 but I am also getting errors with that. I did also need to reinstall the JRE. So with all the changes, I don’t even know where to start.
I would greatly appreciate any help to get me back to where I was.
Thank you.
2016-05-18 23:28:57.497 [WARN ] [.u.component.AbstractLifeCycle] - FAILED SelectChannelConnector@0.0.0.0:8080: java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind0(Native Method) ~[na:1.8.0_91]
at sun.nio.ch.Net.bind(Unknown Source) ~[na:1.8.0_91]
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source) ~[na:1.8.0_91]
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source) ~[na:1.8.0_91]
at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.Server.doStart(Server.java:273) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.ServerInstanceWrapper.start(ServerInstanceWrapper.java:166) [org.eclipse.jetty.osgi.boot_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.JettyServerServiceTracker.serviceChanged(JettyServerServiceTracker.java:112) [org.eclipse.jetty.osgi.boot_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:451) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.DefaultJettyAtJettyHomeHelper.startJettyAtJettyHome(DefaultJettyAtJettyHomeHelper.java:156) [org.eclipse.jetty.osgi.boot_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.osgi.boot.JettyBootstrapActivator.start(JettyBootstrapActivator.java:119) [org.eclipse.jetty.osgi.boot_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at java.security.AccessController.doPrivileged(Native Method) [na:1.8.0_91]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
2016-05-18 23:28:57.770 [WARN ] [.u.component.AbstractLifeCycle] - FAILED org.eclipse.jetty.server.Server@cb60ad: java.net.BindException: Address already in use: bind
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) ~[org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.Server.doStart(Server.java:273) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
2016-05-18 23:28:58.956 [WARN ] [.i.s.JettyServerServiceTracker] -
at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182) ~[na:na]
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311) ~[na:na]
at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260) ~[na:na]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) ~[na:na]
at org.eclipse.jetty.server.Server.doStart(Server.java:273) ~[na:na]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.ServerInstanceWrapper.start(ServerInstanceWrapper.java:166) ~[na:na]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.JettyServerServiceTracker.serviceChanged(JettyServerServiceTracker.java:112) ~[na:na]
2016-05-18 23:28:59.183 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.2).
2016-05-18 23:28:59.764 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-05-18 23:28:59.796 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-05-18 23:29:03.068 [INFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
2016-05-18 23:29:03.092 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = COM4
2016-05-18 23:29:03.094 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, healtime = 1
2016-05-18 23:29:03.096 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, softReset = true
2016-05-18 23:29:03.098 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2016-05-18 23:29:03.105 [INFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2016-05-18 23:29:03.114 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
2016-05-18 23:29:03.117 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. Soft reset is true.
2016-05-18 23:29:03.119 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port COM4
2016-05-18 23:29:03.609 [INFO ] [b.z.i.protocol.ZWaveController] - Serial port is initialized
2016-05-18 23:29:03.635 [INFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
2016-05-18 23:29:06.715 [INFO ] [rialApiGetInitDataMessageClass] - NODE 1: Node found
2016-05-18 23:29:06.719 [INFO ] [rialApiGetInitDataMessageClass] - NODE 4: Node found
2016-05-18 23:29:06.723 [INFO ] [rialApiGetInitDataMessageClass] - NODE 5: Node found
2016-05-18 23:29:06.727 [INFO ] [rialApiGetInitDataMessageClass] - NODE 6: Node found
2016-05-18 23:29:06.732 [INFO ] [rialApiGetInitDataMessageClass] - NODE 7: Node found
2016-05-18 23:29:06.736 [INFO ] [rialApiGetInitDataMessageClass] - NODE 9: Node found
2016-05-18 23:29:06.740 [INFO ] [rialApiGetInitDataMessageClass] - NODE 11: Node found
2016-05-18 23:29:06.743 [INFO ] [rialApiGetInitDataMessageClass] - NODE 12: Node found
2016-05-18 23:29:06.747 [INFO ] [rialApiGetInitDataMessageClass] - NODE 13: Node found
2016-05-18 23:29:06.751 [INFO ] [rialApiGetInitDataMessageClass] - NODE 14: Node found
2016-05-18 23:29:06.755 [INFO ] [rialApiGetInitDataMessageClass] - NODE 16: Node found
2016-05-18 23:29:06.759 [INFO ] [rialApiGetInitDataMessageClass] - NODE 17: Node found
2016-05-18 23:29:06.763 [INFO ] [rialApiGetInitDataMessageClass] - NODE 18: Node found
2016-05-18 23:29:06.766 [INFO ] [rialApiGetInitDataMessageClass] - NODE 19: Node found
2016-05-18 23:29:06.768 [INFO ] [rialApiGetInitDataMessageClass] - NODE 20: Node found
2016-05-18 23:29:06.770 [INFO ] [rialApiGetInitDataMessageClass] - NODE 21: Node found
2016-05-18 23:29:06.772 [INFO ] [rialApiGetInitDataMessageClass] - NODE 24: Node found
2016-05-18 23:29:06.773 [INFO ] [rialApiGetInitDataMessageClass] - NODE 25: Node found
2016-05-18 23:29:06.775 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2016-05-18 23:29:06.777 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2016-05-18 23:29:06.780 [INFO ] [rialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2016-05-18 23:29:06.783 [INFO ] [rialApiGetInitDataMessageClass] - # Nodes = 18
2016-05-18 23:29:06.784 [INFO ] [rialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2016-05-18 23:29:06.996 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 18: Unsupported command class SCENE_ACTUATOR_CONF
2016-05-18 23:29:07.008 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class SCENE_ACTUATOR_CONF
2016-05-18 23:29:07.273 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 12: Got an error while sending data. Resending message.
2016-05-18 23:29:07.421 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 12: Got an error while sending data. Resending message.
2016-05-18 23:29:07.607 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 12: Node is DEAD. Dropping message.
2016-05-18 23:29:07.773 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 6: Got an error while sending data. Resending message.
2016-05-18 23:29:07.879 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 6: Got an error while sending data. Resending message.
2016-05-18 23:29:08.025 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2016-05-18 23:29:08.211 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 9: Got an error while sending data. Resending message.
2016-05-18 23:29:08.357 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 9: Got an error while sending data. Resending message.
2016-05-18 23:29:08.485 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 9: Node is DEAD. Dropping message.
2016-05-18 23:29:08.534 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class POWERLEVEL
2016-05-18 23:29:08.568 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class POWERLEVEL
2016-05-18 23:29:08.777 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SWITCH_ALL, value = 255, ignoring.
2016-05-18 23:29:08.808 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
java.lang.ArrayIndexOutOfBoundsException: 5
at org.openhab.binding.zwave.internal.protocol.SerialMessage.getMessagePayloadByte(SerialMessage.java:313) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.getString(ZWaveNodeNamingCommandClass.java:169) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.processNameReport(ZWaveNodeNamingCommandClass.java:228) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveNodeNamingCommandClass.handleApplicationCommandRequest(ZWaveNodeNamingCommandClass.java:141) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:223) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:196) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:191) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1166) ~[na:na]
2016-05-18 23:29:09.521 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'demo.sitemap’
2016-05-18 23:29:09.609 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'db4o.persist’
2016-05-18 23:29:09.619 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'exec.persist’
2016-05-18 23:29:09.633 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'logging.persist’
2016-05-18 23:29:09.645 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist’
2016-05-18 23:29:09.680 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'demo.rules’
2016-05-18 23:29:09.993 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'demo.script’
2016-05-18 23:29:10.028 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'demo.items’
2016-05-18 23:29:10.248 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.com”}
2016-05-18 23:29:10.253 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-05-18 23:29:10.369 [WARN ] [.httpclient.HttpMethodDirector] - Unable to respond to any of these challenges: {oauth=OAuth oauth_problem=“OST_OAUTH_PARAMETER_ABSENT_ERROR”, realm=“yahooapis.com”}
2016-05-18 23:29:10.373 [WARN ] [g.openhab.io.net.http.HttpUtil] - Method failed: HTTP/1.1 401 Unauthorized
2016-05-18 23:29:10.601 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule ‘Set random room temperatures’: Could not invoke method: org.openhab.model.script.actions.BusEvent.postUpdate(org.openhab.core.items.Item,org.openhab.core.types.State) on instance: null
2016-05-18 23:29:10.645 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule ‘Update max and min temperatures’: cannot invoke method public abstract org.openhab.core.types.State org.openhab.core.persistence.HistoricItem.getState() on null
2016-05-18 23:29:13.785 [ERROR] [WaveController$ZWaveSendThread] - NODE 5: Timeout while sending message. Requeueing - 2 attempts left!
2016-05-18 23:29:13.964 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 5: Got an error while sending data. Resending message.
2016-05-18 23:29:13.992 [ERROR] [b.z.i.protocol.ZWaveController] - Exception during Z-Wave thread: Input.
You have something already running on your machine bound to port 8080, 8433, or 5555. This isn’t a JRE issue but a network port conflict issue.
You either need to identify what program you have running that is using these ports, or modify your start.bat to run openHAB on alternative ports.
rlkoshak,
I really appreciate the help with this. I should have seen it. I made the change to the ports and now it is working as expected.
Thank you.
