Hi
I am planning to leave my current Vera automation gateway.
I bought a aeon labs sticks and will soon setup an emonPi photovoltaic monitoring server (runs on Raspberry PI 2).
I was wondering if it can coexist with an openhab server.
Does anyone have experience?
I don’t know the details of emoncms, but I don’t see why they can’t work on the same Pi - openhab should be able to coexist independently…
However, the processing power of the RPi is quite low - the RPi2 might be ok, but I suspect that the original RPi might be a bit underpowered depending on how many bindings etc you intend to run.
I’m looking to do the same, I’ve just upgraded my pi to a RPi2 and want to consolidate another pi running only emon to the openhab pi (I only use the emon pi as a gateway, everything is stored at emoncms.org.
I assume you’re using the open energy monitor pi-board, and followed the emoncms install - we’re there any problems/extra steps needed?
I have since the post moved to a separate emonpi because I had messed up something on emonpi side.
However the steps dhould be those and there should ne no problem (I ran it for a few weeks , then I made some mess)
