I have setup private Openhab Cloud and everything is working fine.
- I could access Site Map (Basic UI) from bwowser and Android/IOS app
- I could remote access OpenHab MainUI from Chrome, Firebox via the private cloud.
With the above, i assume cloud server setting is correct and working. BUT, when i use Android/IOS app to access Main UI, it prompts me for Username/password of the cloud. I have verified my cloud config.json, and it is correctly configured as below:
"system": {
"host": "xx.com",
"port": "443",
"protocol": "https",
"logger" : {
"dir": "./logs",
"maxFiles" : "7d",
"level" : "debug",
"morganOption" : "dev"
"proxyHost": "home.xx.com",
"proxyPort": "443",
"subDomainCookies": true,
"muteNotifications": false
Cloud’s nginx server also added the following in ‘/’ location block:
add_header Set-Cookie X-OPENHAB-AUTH-HEADER=1;
proxy_set_header Authorization "";
But, problem remains. If you have configured something similar, please give some pointers … cheers.
