I’m beginning to have problems with my OH installation, I noticed it happening after Build #1073 i’m now on openHAB 2.2.0 Build #1078 having same issue.
After a shutdown in Karif I’m getting this at log in
Please stand by while UIs are being installed. This can take several minutes.
I couple of shutdown can solve the issue, but mainly I have to reboot the entire server.
In karif I get this
10:39:53.788 [WARN ] [e.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type JS
10:39:53.788 [WARN ] [inding.modbus.internal.Transformation] - couldn't transform response because transformationService of type 'JS' is unavailable
Do you have anything defined in .items or even in .things files?
Ramp up logging if you haven’t done that yet (at least set org.apache.karaf to DEBUG and org.eclipse.smarthome too, eventually).
Check your logs what’s being loaded first and what’s last for both, a ‘working’ restart or a non-working one.
Are rules loaded before things ? before items ? before persistence config ?
