I have been following some tutorials to install Openhab on Raspberry Pi.
Everything is running ok… the autostart is running.
But my problem is that the Autostart is running on my background…
Any of you guys knows how can I run it on main Screen… My objective is see what is going on with my openhab in real time…
The general consensus here is to install OH according to the OH Wiki, which will assure that relevant directories are located where they need to be, as well as user and application ownerships and rights required are in place… this approach ensures a baseline for people who want to help you out, which without that baseline is difficult to do.
I suggest to follow a modular approach to installing a Raspberry:
a) install the image, and configure what you basically need, e.g. your user and group, network tools and services, etc.
b) save this image, before you install any applications
c) start with OH and see how you go; in case you buggered it up, simply re-install the image saved under b) and start again.
Thank you very much by your reply.
I found the file inside /var/log/ using filezila directory but when I execute the tail command the system do not find the directory.
Well, since you didn’t install using apt-get the logs are put where ever it is that you did install it. There is a logs folder and you should find an openhab.log file in there.
But I highly recommend installing via apt-get, particularly if you are unfamiliar with Linux which you seem to be.
