- Platform information:
- Hardware: Raspberry Pi 3 B+ Rev 1.3 Memory: Free 0.19 GB Used 0.75 GB
- OS: Raspbian GNU/Linux 9 (Stretch)
- Java Runtime Environment: Zulu embedded 8.25.0.76-linux-aarch32hf, build 1.8.0_152-b76
- openHAB version: 2.4.0~M4-1
- Issue of the topic: Openhab reboots without any warning in the logs. This started happening when I upgraded to M4. I noticed this happening with a few different scenarios.
- when i update a thing (such as add a location in the configuration portion of the thing)
- when updating a rule using VisualStudioCode
The strange parts are that I can do either one of the listed items and have no problems but then randomly the system reboots without any log information, or any that I can find.
Bindings-
Expire
Zwave
WeatherUnderground
Astro Binding
DSC Alarm Binding
I have followed the instructions for the zwave binding, removed the binding, deleted the things, installed the binding and connected the existing items back to the newly discovered things.
Notice there is a Zwave Plus USB Dongle listed and did not use this thing as the master zwave device, I used the old Zwave Serial Controller for the updated binding-I think I read in a post to ignore this new thing so that is what I did
I have tried 2 other things, update openhab through the SSH interface and the OpenHabian configuration tool and uninstalled and re-installed expire binding.
Because the log doesn’t show a problem before it reboots I don’t know where to look from here?
