Hi everyone,
I am getting kind of desperate while trying to update OpenHAB. I am trying to update from 2.5.5-1 to the latest stable release which seems to be 2.5.10-1 at the time of writing.
At first, I had trouble completing the updates at all. So I found an advice to clean my cache. That was the first thing I did. Another problem which persists is the
FireMotD: Info: No FireMotD ExportFile detected. Please generate with “sudo ./FireMotD -S”
warning.
Here is what I did:
Run openhabian-config -> 10 -> Install FireMotD. Completed without errors
Exit openhabian-config
Run sudo apt-get update. No errors
Run sudo apt-get install openhab2. Completed successfully.
Open second SSH connection to check version: "Welcome to OpenHABian 2.5.10-1 (Release Build)
Restarted my Raspberry with sudo shutdown -r
After logging in with ssh the FireMotD “No export file” error is back and my OpenHAB version is at 2.5.5-1 again.
I have no clue how to fix this. I have run the update procedure at least 10 times, from the command line, from openhabian-config and with and without the openhab2-addons. Always the same result: Back at 2.5.5-1 everytime.
Looks like the troubles aren’t over yet. My backup was not stored on the SD card. I checked the file before I shutdown the system running on the old card and it was there. When I mounted the card on another computer the zip file is gone.
Really weird.
